KingAirer said:Its a "pain" (pun intended) to see strobe lights taxiing by at night. I always turn them off when i have the beacon going. When flying an aircraft that only has strobes and no beacon, is there anything legal that says that must be on for taxii??
For example... you have no beacon installed on the a/c but have strobes. If you are in IMC at night, you may turn the strobes off b/c having them on would affect the safety of flight. I would assume the same would hold true if you were taxiing around on the ground. I thought there was a reg that stated this but I can't remember off the top of my head. Maybe some else will be able to post it.
DoinTime said:
91.209
(b) Operate an aircraft that is equipped with an anticollision light system, unless it has lighted anticollision lights. However, the anticollision lights need not be lighted when the pilot-in-command determines that, because of operating conditions, it would be in the interest of safety to turn the lights off.
