Street captains?
exeagle said:
if you are interested in mesa , make sure you have 1 of these requirements for a type rating in a simulator...
) Hold a type rating for a turbojet airplane of the same class of
airplane for which the type rating is sought, or have been designated by
a military service as a pilot in command of an airplane of the same
class of airplane for which the type rating is sought, if a turbojet
type rating is sought;
(B) Hold a type rating for a turbopropeller airplane of the same
class as the airplane for which the type rating is sought, or have been
appointed by a military service as a pilot in command of an airplane of
the same class of airplane for which the type rating is sought, if a
turbopropeller airplane type rating is sought;
(C) Have at least 2,000 hours of flight time, of which 500 hours
must be in turbine-powered airplanes of the same class as the airplane
for which the type rating is sought;
(D) Have at least 500 hours of flight time in the same type of
airplane as the airplane for which the type rating is sought; or
(E) Have at least 1,000 hours of flight time in at least two
different airplanes requiring a type rating.
Where did you get this???? Some type of reg I don't know about.
pipejocky its the future suck it up if you dont like it dont come back to this industry regionals will and should grow!!!
There is other requirements that can have this reduced. It basicaly says you just need the ATP and some current flying. This is allowed with a structured IOE program. I was wandering because in the DHC8 class I was in, they wanted to turn CFI's with ATP mins into street captains. They must have had a way of doing this. Not trying to be argumentitive at all, just trying to figure how they were planning on pulling this off.
......issued an additional rating or an airline transport pilot certificate with an additional rating, as applicable, with a limitation. The limitation shall state: "This certificate is subject to pilot-in-command limitations for the additional rating."
(9) An applicant issued a pilot certificate with the limitation specified in paragraph (g)(8) of this section --
(i) May not act as pilot in command of the aircraft for which an additional rating was obtained under the provisions of this section until the limitation is removed from the certificate; and
(ii) May have the limitation removed by accomplishing 25 hours of supervised operating experience as pilot in command under the supervision of a qualified and current pilot in command, in the seat normally occupied by the pilot in command, in an airplane of the same type for which the limitation applies.
thanks for the clarification. I had heard from a friend of mine that several people slated as street capts. got moved over to FOs because of these requirements.
good luck jim, which ever way you choose. I would only ask that you keep in mind that the F.O.'s you will be flying with can help you out alot in a 121 enviroment.
THIS JUST IN.......
AIRTRAN AIRWAYS JUST SENT OUT A LETTER TO ALL QUALIFIED PILOTS....
"WE ARE UNABLE TO FILL OUR CAPTAIN SLOTS THIS YEAR WITH OUR CURRENT INVENTORY OF FIRST OFFICERS. APPLICANTS FOR CAPTAIN POSITIONS MUST HAVE..
A. 1500TT
2. 3000 PIC
D. HAD SEX IN THE PAST 12 MONTHS
3. HAVE A CURRENT DRIVERS LISCENSE IN THE STATE OF EUPHORIA
IF YOU MEET THESE QUALIFICATIONS, PLEASE CONTACT HR AT 1-800-WHATEVER"
tHAt is all I have to say about that right now
