Straight in approach at Non Controlled Field
So to conclude:
-You can turn a long final however far you are away from the airport to land
-If turning on final via opposite direction of turn prescribed by part 93 traffic pattern, you must turn this final outside of 5 NM.
What I find hilarious is that the FAA's recommended traffic pattern entry calls for an INITAL right turn onto downwind to begin left turns. This seems hypocritical!?!
My questions:
On depature from class G airports, you can turn any direction after depature that you want (91.126 does NOT mention depatures like 91.127 for class E does).
So, if departing a class G you can make a right turn out assuming the traffic pattern is established left traffic. In class E you cannot, per 91.127 (b). However, what if you are at an airport that has class E starting @ 700', would you abide by 91.126 for depatures or 91.127. Also, what is the definition of "vicinity" as in "operating on or in the vicinity of an airport in class E airspace"? I'm guessing the 91.127 rules would apply for the above situation as the class G airport (up to 700') is in the vicinity of class E airspace, therefore you must make all turns on departure in the direction of the prescribed traffic pattern.
-How about practice approaches? We do them VFR without approach guidance here at my school (Denver center hardly has RADAR coverage) and often make procedure turns within 5 NM. If we make a right hand procedure turn within 5 NM at a class E airport with a runway that has right traffic, technically are we violating 91.126/91.127? I'm asking FAR standpoint only, not AIM.
-What about visual approaches? They are still an IFR manuver, but do they fall under 91.126/91.127? If cleared for visual approach, must you enter the pattern with left turns @ a class G or E airport, or turn final outside of 5 NM? I'm assuming yes (as the 737 situation showed), but just wanted clarification
-What if you shot an approach and circled to land? Aim 5-4-18 f 2 states that you must consider standard left traffic. I had thought that you could circle any way you'd like.
Am I making this too hard?
Sorry for all the questions, I should probably know all this but it seems there are so many variables.
Prpjet....
Thanks for pointing out the references on the FAA site...
I guess this is a "grey" area....or is it a "gray" area..
I was just going by 61, where it lists the requirements for certificates and ratings.
SIR MILO said:
You guys are right on many things, but the basis of it being illegal and why the captain might of given you a look as to why it would be illegal is that your maximum for a straight in is a 5 mile final..
I thought Mar and ASquared might have posted DOC's response to their query on this issue on the Pro Pilot BB but I'll do it for them:
http://www.propilot.com/ then select DOCs FAR Forum Bulletin Board and you'll see the question on VFR Uncontrolled Straight-Ins including discussion of the so-called "Five Mile Rule".
Here's the gist:
"Yes, you can make a straight-in approach and landing. FAR 91.126(b) applies to the direction of turns, but it does not require you to actually make turns in order to enter the pattern. It merely imposes a standard direction-of-turn for any turns that happen to occur.
Radio contact is not required in Class G airspace (but it is still a good idea), so the fact that you make periodic pattern reports is irrelevant.
The AIM pattern entry recommendations are just that -- recommendations. But failing to follow AIM guidance COULD lead to enforcement action under FAR 91.13.
The length of the straight-in is irrelevant.
FAR 91.126(b):
"(b) Direction of turns. When approaching to land at an airport without an operating control tower in a Class G airspace area -
(1) Each pilot of an airplane must make all turns of that airplane to the left unless the airport displays approved light signals or visual markings indicating that turns should be made to the right, in which case the pilot must make all turns to the right; and
(2) Each pilot of a helicopter must avoid the flow of fixed wing aircraft."
Hope this helps,
DOC
and ref the "five mile rule":
Posted by mar on December 08, 2004 at 16:47:27:
Doc, you said the length of the straight-in final is irrelevant but there was a 737 crew busted in Kotzebue, Alaska for turning a "short" dog-leg to final.
I don't have the text of the decision but I believe Asquared does.
The bottom line is that the FAA ruled the length of the final must be appropriate to the category and class of the aircraft.
In other words, a five mile straight-in is appropriate for a single engine cessna but a jet transport should be established on final much further out.
Sorry for the paraphrasing, hopefully Asquared will provide the exact text.
Best.
Mar:
I believe you and I have no doubt that the FAA may consider excessively short final approaches to be careless or reckless. But I was referring to the fact that Late Bloomer was probably being told by someone that some 'rule' exists (it doesn't) that straight-ins cannot exceed 5 miles (maximum length).
It's the same old thing again - there are people who just aren't satisfied with the existing volume of rule-making and feel the need to create more rules. It's already hard enough to keep up with FAA, TSA, and Congress....:-)
Regards, Doc
