The bank should be corrected with opposite rudder until the stall has been completely recovered from, at which point you can use aileron.
If you think about it, using opposite aileron will cause the aileron on the low wing to deflect downwards -- this will increase the angle of attack of the low wing, which is already stalled, and the wing will continue to drop.
