Squawk!
  • Thread starter Thread starter TDTURBO
T
TDTURBO
Airplane Maintance
> >After every flight, pilots fill out a form called a gripe sheet,
which
> >conveys to the mechanics problems encountered with the aircraft
during the
> >flight that need repair or correction. The mechanics read and correct
the
> >problem, and then respond in writing on the lower half of the form
what
> >remedial action was taken, and the pilot reviews the gripe sheets
before
> >the next flight. Never let it be said that ground crews and engineers
lack
> >a sense of humor!
> >Here are some actual logged maintenance complaints and problems as
> >submitted by Qantas pilots and the solution recorded by maintenance
> >engineers.(Bythe way, Qantas is the only major airline that has
never had an
> >accident.)
> >P = The problem logged by the pilot
> >S = The solution and action taken by the engineers
> >P: Left inside main tire almost needs replacement.
> >S: Almost replaced left inside main tire.
> >P: Test flight OK, except auto-land very rough.
> >S: Auto-land not installed on this aircraft.
> >P: Something loose in cockpit.
> >S: Something tightened in cockpit.
> >P: Dead bugs on windshield.
> >S: Live bugs on back-order.
> >P: Evidence of leak on right main landing gear.
> >S: Evidence removed.
> >P: DME volume unbelievably loud. (Distance Measuring Equipment)
> >S: DME volume set to more believable level.
> >P: Friction locks cause throttle levers to stick.
> >S: That's what they're there for.
> >P: IFF inoperative.
> >S: IFF always inoperative in OFF mode.
> >P: Suspected crack in windshield.
> >S: Suspect you're right.
> >P: Number 3 engine missing.
> >S: Engine found on right wing after brief search.
> >P: Aircraft handles funny.
> >S: Aircraft warned to straighten up, fly right, and be serious.
> >P: Target radar hums.
> >S: Reprogrammed target radar with lyrics.
> >P: Mouse in cockpit.
> >S: Cat installed.
> >P: Noise coming from under instrument panel. Sounds like a midget
pounding
> >on something with a hammer.
> >S: Took hammer away from midget.
QANTAS aircraft are equipped with target RADAR? really?? What are they targeting? Ansett?
If QANTAS has never had an accident, what word would you use to describe that "occurance" which left a QANTAS 747 sitting in the middle of a golf course with no landing gear?
