speed question
Bubba Dog
Total Time
enough
What is the max speed you can be at 2500 ft and 7 miles from Myrtle Beach Airport(KMYR) in a jet a/c?
Is it no faster than 200 knots out to 10 miles and what altitude?
regionalcap
Total Time
8000
FAR 91.117
(b) Unless otherwise authorized or required by ATC, no person may operate an aircraft at or below 2,500 feet above the surface within 4 nautical miles of the primary airport of a Class C or Class D airspace area at an indicated airspeed of more than 200 knots (230 mph.). This paragraph (b) does not apply to any operations within a Class B airspace area. Such operations shall comply with paragraph (a) of this section.
puddlejumper
Unemployed /Contract User
Total Time
6030
J.Otto
Total Time
all sounds right.
250 ias below 10k except around C or D below 2,500' and 4 NM, it is 200 ias.
Stepclimb
Total Time
14:59
all sounds right.
And don't forget 200 KIAS under the shelf(s) of Class B or proceeding through the VFR corridor.
CA1900
Big Member
Total Time
11000+
And just to get it out of the way early in the thread, Class B itself has no speed limit designated.
Terry Hunter
Silence!
Total Time
<0>
Is the 200 KIAS below class B the reason that controllers are starting to tell pilots when they are leaving class B during vectors?
