speed limit
Re: heavies out of any airport.
Item 1: We often will exceed 250 below 10000, legal under the provisions of FAR 91.117(d). At max TOGW the MD-11 climbs at 289kts indicated before accelerating at 10000'.
Item 2: The 250 kt restriction does not apply to the above (although we do advise them of the planned speed (if above 250) when there's a limit just to help them out in their planning), but they are instead thinking of the speed as the aircraft pass 10000'. Most jet aircraft accelerate to normal climb speed at that time (it's 355 kts indicated for our MD-11s).
Item 3: Not really related to the above, but I also give ATC a courtesy advisory of our approach speed when really heavy so they don't try to sequence us in too tight. When very heavy it's 167kts without any special additives such as strong winds or gust, etc. Not pretty if they try to sequence us in tight behind a 737, etc.
Flight Junkie said:
250 is correct except for one class B...IAH.
correct....sort of.. Speeds in excess of 250KIAS are only approved in the houston class B on departure (not arrival) and only when accompanied by the phrase "no speed limit". it is not automatic. SFAR
ex. "Jetlink 3585 cleared direct Palacios no speed limit"
TriStar_drvr said:
Approach: Continental xxx, say speed.
CO xxx: (after long pause) two fifty.
Approach: Yea right! (with sounds of laughter in the background)
LOL...ive heard that before :p
ive heard this:
Tulsa Approach: "gulfstream XXX say speed."
Gulfstream XXX: (young voice) "Two hundred and Eigh.."
long pause
Gulfstream XXX: "(capt. greyhair) "Two fifty"
Tulsa Approach: "Oh really! Back it down to 220, your overtaking an MU-2 by 100 knots!"
I laughed my A$$ off!!
