Simple Oil Filter Drain (AvBrief.com)
Interesting idea. This a challenge in my Carbon Cub FX-3 oil change. I have the trick from @Tsquared of using a plastic grocery bag with towels on the bottom for absorption, I use two bags as they often have holes, yeah, don't ask how I learned that, stuffing them under the filter with open end up of course.
I use an empty oil bottle with the side cut out. It fits under the oil filter. Just need to be careful not to spill the collected oil when removing it.
I have found that a simple yogurt container works well with some patience.
Start by wedging the container between the firewall and the engine under the oil filter adapter. Then loosen the oil filter just enough for it to start draining slowly into the container. Once drained, then the container can be removed and the filter removed. Just a small amount of towel is needed to cleanup any remaining drips.
Much better than rushing the old filter removal and trying to cover it in a plastic bag…
What I always do is poke a hole in the top of the oil filter right after removing the top cowl to allow more of the filter oil to drain back into the engine overnight - I am going to apply some compressed air to that hole on my next filter change and see if that will help get more of the oil out of the filter and back into the sump
