wow, there's a lot of 'great spirits' sharing their wisdom with us lesser aviators
One of my personal mottos since I became a pilot, has been that, as soon as you start to think you know everything about flying and cant learn from anybody anymore, you become a liability, to yourself, your passengers, crew, people in the airspace with you and people below your flightpath.
I only have 45....ok, 44.9 hours on the PA34 Seneca I, and 1100ME, but I'd like to chip in my 2 cents....
During training, my instructor did fail an engine using the fuel cutoff. I think he did it more because of the position of the fuel selector switches and being able to reach them surreptisiously than anything else! But, he never failed an engine below ....say 3000'? (this is in South Africa b.t.w.)
My personal SOPs, for every aircraft, be-it SE or ME, that has the capability to select one tank only, or crossfeed, I check that this function will work.
On the C402C I fly regularly, early during the taxi, I crossfeed, then select normal feed and test the aux pumps on high, well before I get to the holding point and do my runups. This way I know that the crossfeed will work, the aux pumps will provide fuel at high pressure to the engines if an engine driven pump will fail, and during the runup I can see the engines feeding off their respective tanks without problems.
One instructor, during my F406 rating, had me do single engine circuits and landings, with one SE go-around. The 'failed' engine was set at zero thrust only, on the landings I got the failed engine back to use, but the go-around was SE only.....,man was that some hairy s-h-i-t ! Not fun at all, luckily it is a pretty powerfull machine and empty with the two of us one engine's 500horses was enough....but still not cool.
During upper air work the one engine was feathered (at idle) and we did Vmca and steep turns etc. Sweating like a pig, I was.
A ME aircraft on one engine is not a beast to play around with.
Especially an underpowered one like a Seneca I.
