ProFracPilot
What's it doing now?
- May 1, 2003
If we want to be perfectly correct, you only have to demonstrate recovery from an approach to a stall by recovering from the first indication.
You win :beer:
I think you must mean a .299 Line Check.
A .297 Check requires at least 1 (turning) stall. 2 stalls may be waived. So, if someone is signing off your .297's without having you demonstrate at least 1 stall, then your check rides have been invalid.
2 things you never want to hear in the cockpit.
Captain saying " Watch this"
F/O saying "I have an idea"!
I guess my 50 or 60 (lost count years ago) 297 checks have never been valid because I have never been asked to do any stall stuff on that ride. Only demonstrate instrument proficiency. Where is the word "stall" mentioned in 135.297. I can't find it.
Sec. 135.297
(1) The instrument proficiency check must --
(i) For a pilot in command of an airplane under §135.243(a), include the procedures and maneuvers for an airline transport pilot certificate in the particular type of airplane, if appropriate; and
If appropriate is the key. In almost 40 years of this I never heard of anyone having to do anything other than instrument procedures on a 297 check. As a previous check airman I would have used the PTS stuff only if someone was so marginal (but still meeting min standards) that the PTS could be used to wash them out. It can be a little hard to eliminate someone solely on 297 stuff, but really easy if you use the basic stuff. That being said, I never encountered that situation.
Not to worry.....when you have the same last name as the D.O., you won't be fired anyhow.
Are you serious? Are you saying a new-hire pilot with no line experience can pass your initial PIC check without doing a solitary non-instrument maneuver? How about a V1 cut? Remember, a 135.293 check is not required if a .297 check is completed.
My understanding is the "if appropriate" statement in part 135.297 refers to the capabilities of the aircraft used for the checkride. It's pretty clear to me that if an ATP is required to fly the machine under Part 135, all ATP maneuvers must either be performed or waived if waiverable. Ditto commercial maneuvers if a Commercial certificate is required.
The 293 section says a 297 check MAY be substituted for a 293. A 297 does not say it SHALL or WILL substitute for a 293. The final outcome is determined by which box is checked. If giving a 297 check there is no requirement to check the 293 box...only the 297. The checks are usually combined in the sim, but if done in an aircraft it adds quite a bit of expense to do anything more than the instrument checks required in 297. If an individual had a current 293 I only checked the 297 box on the form.
If appropriate: (i) For a pilot in command of an airplane under §135.243(a), include the procedures and maneuvers for an airline transport pilot certificate in the particular type of airplane, if appropriate; and
Move the comma from being located after "airplane" to after "certificate" and your belief would be correct. However, as written, "if appropriate" refers to the procedures and maneuvers. Typical FAR...the placement of a ,:; etc allows 50 different interpretations.
Not a moderator input, just personal observation:
I have performed a .297 ride almost every year since 1994.
I have never been asked to do anything that wasn't a specific instrument activity. Approaches only, missed approaches, and a hold.
I have, from time to time, been asked to do a .293 in the interest of time, which can be substituted for the .297 ride, and is actually a shorter ride by about 30 minutes.
The Part 121 world is the same way.
I'm not going to argue the semantics of the wording in Parts 135 or 121 that allow you to substitute what for what and in what circumstances. I'm simply going to tell you that I've had more checkrides than I can count, including multiple type ratings, feds on jumpseats, Check Airman authorizations, checkrides in the actual aircraft as well as the sim, you name it, I've likely done it, and I have never, ever, ever had anyone, including a Fed, from any FSDO (and I've flown for companies based in N.Y., FL, GA, TN, TX, MI, and MN) try to tell me that I had to perform any kind of stall or steep turn or anything else on a .297 ride except instrument competency maneuvers.
You can argue semantics all day long, but reality rules, and the reality is that no one expects a stall on a .297 ride. Not that it CAN'T be given, but simply that no one does, unless they're on a fishing expedition because you've otherwise screwed the pooch with your instrument maneuvers and your basic flying skills are in question.
