SFB - Delta Academy...taxi lessons?
nikoz1200
Just wondering why out of all the Cirrus I taxied behind today in Sanford, not one was on centerline, but in the center of the right side of the taxiway. Is this a new thing they are doing in case of oncoming traffic or something?
It's been that way for years. You're correct in the oncoming traffic situation. It allows for bi-directional taxi.
great idea.....until you whack a wingtip into something then get to explain why you wern't on the centerline.
Sounds like people are making up their own policies now. Next it will be landing on the right side of the runway cause the deer usually jump out from the left.
I've never flunked an applicant on the taxi before but there is a first time for everything.
Actually thats how ground says to taxi. Ground will say something like "taxi to 9L via Kilo right side"
Thats pretty messed up! Out of curiosity...how wide is the taxiway?
me: "unable"
since when does ground sign for the plane?
That is the most stupid clearance to accept. Good luck. If you see a QS tail coming please stop and dont taxi next to me.
I don't think that would be much of a problem since most of the QS tails I see are already parked on the ramp and haven't moved in some time
lol.....ok since you threw that card out, wanna compare W2's?
I didnt think so.
Dont turn this into some juvenile thread. My point being that ill get kinda pissed if a ground controller attempts to give me unsafe taxi instructions. Ill be even more pissed if one of those students takes him up on that offer while im in motion.
Hey brokeflyer, you sounds like one of the funnest people to fly with. I'd love to spend a 4 day trip with ya (NOT)!
Yeah SFB and DAB routinely use taxiways as bi-directional taxiways for small GA a/c to keep traffic moving. BTW, what is there to hit with a wingtip anyway when your wings don't even go off the side of the taxi way? Don't sweat the small stuff big fella...
im a blast to fly with as long as you are safe......but you'd have a long way to go before you have to worry abouyt 4 days with me. That's what shouldn't be sweated.
once you become stupid then I'll re-educate you.
and the answer to second part of your question will only be known by the FAA inspector that askes you what your descion making process was captain.
When you become a PIC you'll sweat the small stuff kid. That's the stuff that gets you violated.
any other questions?
I disagree with the post made by another NetJets pilot.
I will agree that the hazard level increases when conducting passing operations on airport taxiways, but in my opinion it is not an unsafe operation in most cases when light GA aircraft are involved.
The light GA aircraft involved have great visibility, they can easily see where their wingtip is from the cockpit at all times. In addition, because of the smaller wingspan, they can use the centerline of the taxiway as a "no transgression zone" which provides another indication that their wingtip will not contact another aircraft. Airports are designed for a "critical aircraft" which is usually much bigger than the average light aircraft. All the taxiway pavement, obstacle free zones, etc, is bases on the larger wingspan aircraft, giving smaller wingspan aircraft much more room to operate safely within. Due to all of the above characteristics, the increased hazard of being off the centerline is very small for light GA aircraft, and usually acceptable.
I have conducted two airplanes on the same runway takeoff, and three airplanes landing on the same runway at the same time, with the FAA's blessing. This was during the Sun N Fun fly in, and I was following the standard FAA procedures for these events. These operations are even more extreme than the routine taxiway passing operations that occur at some airports on a routine basis.
That said, I would not attempt these procedures in a 50' wingspan corporate jet, as the characteristics that allow me to conduct safe passing operations in the smaller aircraft do not exist in a Citation jet. As such, I would not accept any ATC instruction to have me attempt this. I would also protest if I was told to just stop on the taxiway and allow another aircraft to attempt a taxiway passing that could place my aircraft in jeopardy as well.
Finally, as we all know from our student pilot days, just because you are on a taxiway centerline does not mean you are clear of all obstructions. I did a trip a couple of days ago (out of SFB) and the small airport where we landed minimum room for a citation jet, and our wingtip hung over the only center line for the ramp. The best we could due (because of ramp space and no aircraft tug at the airport to push the plane (except the wheelbase) into the grass) was to place a couple of traffic cones near the protruding wingtip to try and alert other aircraft to the hazard.
I feel that taxiway passing operations are fine for smaller aircraft, due to the nature of those aircraft. The same operation is too hazardous for larger wingspan aircraft.
