Rick James
- Mar 7, 2005
AIM 1-1-19(d)(1)(b) said:(b) Aircraft using GPS navigation equipment under IFR must be equipped with an approved and operational alternate means of navigation appropriate to the flight. Active monitoring of alternative navigation equipment is not required if the GPS receiver uses RAIM for integrity monitoring. Active monitoring of an alternate means of navigation is required when the RAIM capability of the GPS equipment is lost.
91.171-Yes, that's what Im referring to (Part 91 operators). The AIM reference is interesting, but is it regulatory?VOR check, as in the 30-day VOR check that is required per 91.171?
Aircraft using GPS for navigation have to have backup navigation:
[/FONT]
I'll be the first to admit I have no idea how an IRU applies to the situation, but I'd suspect the Administrator would want 30-day VOR checks performed even on planes with IRUs
Every 40 days?For 135 ops to fly under Op Spec B-43/35, with a single GPS, you must have functioning redundant class I Navigation displayed in the cockpit. Normally VOR on the RMI and F/O's panel. Therefore it must be checked and logged every 40 days.
