Patmack18 said:It's a gun.. you can shoot it at whatever you want. I have Tomcat buddies that were strafing trucks in afghanistan once they'd expended everything else. (And they can't tell the stories without huge grins)
Nalo Boy said:theres a switch that the weapons troops use on the ground to fool the squat switch...so yes it is possible, but no. half the pilots dont even know where it is.
The D models are quite different. It still has the inhibit while on the squat switch. Come to think of it, the typical ground override switch does not allow the gun to drop in the ground, because we action the gun during a weapons operational check and slew it. There is another ground override that is in one of the menu pages on the MPD's, but I can't seem to remember what the function is. I did have an IP tell me one time that you can drive the gun in the ground with the override on (the one on the MPD page, not the weapon ground override we use for a weapons operational check). I'll have to look into it.Hobit said:Weekend,
Did they do away with the -6.45 degree elev. inhibit while on the squat in the L.B.? If memory serves, the only way to override that inhibit on the ground was to pull C.B.'s in the back cockpit. My experience is with the A models only though, I hear your D models are completely different.
I have seen a bird lift it self off the ground with the 30mm when the generators were brought on line. The bird just came out of phase and the armt guys hadn't CBHK'd the elev resolver yet. Pilot had a red face and bruised ego... bad preflight.
Didn't Indiana Jones shoot up some German trucks while his plane was on the ground once in one of his movies? I'm sure it's possible.Slye said:They fired a missle on the ground at some trucks in Iron Eagle, IIRC. It has to be possible if I saw it on TV. I would imagine you can do the same thing with a gun...
