You probably meant to include this, but just to clarify, in order to =log= PIC as a Safety Pilot, you must be =acting= as PIC. That in turn means that you must be qualified to =act= as PIC on the flight. That doesn't just mean ratings, it means the proper endorsements (complex, high performance, tailwheel, etc) as well.SATCFI said:as long as you are appropriately rated in the plane. Otherwise, log it as SIC. Remember, acting as PIC means you buy all the violations.
And just checking. Do you mean as a safety pilot for a private pilot who is doing work in simulated instrument conditions? I know the answer is probably yes, but I've seen a number of people use "safety pilot" in a more generic sense.DA50pilot said:Can a person who is a private pilot, ride along as a safety pilot with another private pilot, and legally log PIC time.
Just curious
SATCFI,
I don't think a safety pilot can log any SIC time. The only time you can log SIC time is if the airplane requires a two pilot crew (at least that's how I interpret the FAR 61 defn of SIC).
Anyone else agree/disagree?
Yes. The FAA disagrees. Read the definition again. It's actually pretty clear.CitationLover said:SATCFI,
61.51
(f) Logging second-in-command flight time. A person may log second-in-command time only for that flight time during which that person:
(1) Is qualified in accordance with the second-in-command requirements of § 61.55 of this part, and occupies a crewmember station in an aircraft that requires more than one pilot by the aircraft's type certificate; or
(2) Holds the appropriate category, class, and instrument rating (if an instrument rating is required for the flight) for the aircraft being flown, and more than one pilot is required under the type certification of the aircraft or the regulations under which the flight is being conducted.
The last part is the classic "safety pilot as SIC" situation since under 91.109(b),
"no person may operate a civil aircraft in simulated instrument flight unless ... the other control seat is occupied by a safety pilot who possesses at least a private pilot certificate with category and class ratings..."
I'm not sure what you think is contradictory. They're just describing different situations.CitationLover said:hey midlife,
if the faa chief counsel wrote that, then why is the faa q&a state to log it as PIC if it is agreed beforehand? seems contradictory, but then again this is the govt.
