Runway heading
"The Collins 4200 database has this departure built as a 184 vector to 1.5 DME, and then turn. As an alternative, you could just fly 184 until abeam DRUSS, and then turn. That's why the waypoint is there."
The departure says fly HEADING 184 DEGREES not a 184 VECTOR.
Flying the 184 heading is not an alternative, it is the compliance to the departure.
Straight from the heads of our Training and Flight Standards Departments and the CVG Tower folks: You WILL fly the 184 degree heading to the 1.5 DME off the ICIZ then turn to 165.
The Collins 4200 seems to be in error here ... for the Bluegrass 18L that is. Now look at the new Churchill RNAV departure for 18L and you will see the reason for the DRUSS waypoint.
Sorry for the confusion, but a 184 Heading and a 184 Vector are the same thing. I did not say 184 Track or that the course was heading 184. In our FMS database, a 184 Vector means just that; the NAV Mode will steer the aircraft to a HEADING of 184, just the same as if you were in HDG Mode.
Thanks for asking a question that you apparently already knew the anwer to, though. You asked for our thoughts and I gave them.
This isn't any different than if you were at FL370 and they told you to fly a heading. You would fly the heading not a track, right? Same thing on t/o with the small difference being that you look at your Jepp chart to get the runway heading.
"Thanks for asking a question that you apparently already knew the answer to, though. You asked for our thoughts and I gave them."
What makes you think I know the answer? The question was, in case you forgot, "Why is DRUSS depicted on the Bluegrass Departure for 18L when the DP clearly says to fly a heading to a DME off the localizer then turn?"
I still don't know the answer.
And I never really cared what the Collins 4200 did or did not do.
ATC only cares about aircraft seperation. All aircraft are operating in the airmass (the wind). As far as radar maps go, they're happy as long as all the aircraft are drifting in the same manner.
This is a point to consider; ATC cares only about aircraft seperation. Think about that, and consider how often you have been vectored on the same ILS intercept heading only to be blown inside the OM before intercepting final, or have you ever taken off in a light GA airplane in a 30 knot crosswind blowing inwards towards the parked aircraft and buildings and saw that "Runway Heading" was getting you scarily close to hitting something, so, IN THE INTEREST OF SAFETY, you crabbed a bit into the wind? Have you? I have.
I know what the book says. I know what controllers do. Both of us have to work together to make it come out right. I track centerline until I'm at circling mins, then I know it's ok to drift over the obstuctions. I am not going to "fly" into another airplane's space by being over the runway during Take-Off flying centerline. During the Take-Off phase, I am staying Over The Runway. When I reach circling minimums, then the Take-Off Phase is completed and I am on the initial climb, so I can turn to runway heading.
Hi!
I recently read about this situation in "Flying" magazine.
At the end, they said you should fly a Track, for safety.
They said that the obstruction clearance and departure setup at the airport, for each runway, is based on flying over the departure end of the runway and beyond on centerline.
If you rotate early and fly the heading, you could be blown into an obstacle and crash if you're IMC and you have no visual references.
I think this should be addressed by the FAA, as there's obviously safety issues here.
It sounds like, legally, you're REQUIRED to fly the rwy HDG, which can make you dead in real life.
cliff
ILG
H320, H324, do you thing anyone really cares?
ATLANTA: triple departures-- RW 28, RW 27R, RW 26L. (From left to right)....
All have 272 deg for the actual runway heading--on the 10-9 page
But if the plane departing on 28 flies 280 deg, and the plane on right runway (26L) flies 260 deg mag,
eventually all 3 may meet at the same point (in theory).
..............Go Steelers!
Align heading bug to nose of aircraft, advance power, it's not rocket science. Been based in ATL thanks.
Atpcliff- An airport will have an ODP or SID if it would be possible to be blown into an obstacle. If you are IMC and meeting or exceeding the standard 200'/nm, 3.3% climb gradient, obstacle clearance is guaranteed (AIM 5-2-8). The need for a higher gradient will be published.
Many local controllers, and I assume this is coordinated with Departure, will adjust the normal assigned headings due to wind. Example: Departing off MDW 22L to the west over IOW, normally assigned heading of 250 on departure. If the wind is out of the south at 25-40 knots, they will probably adjust the heading to 240 so you won't encroach on ORD traffic.
There are exceptions. KPRC tower had an agreement with the local flight schools a few years back that stated the term "fly runway heading" was the same as maintain runway centerline. This was a departure from the norm though.
Here's the key: All the departure profiles are beginning at the departure end of the runway, at 35 feet above the departure end. That's the beginning point from which to measure.
How can you have a specific measuring point if it begins "where ever you rotate". ??
Back to basics: We are all taught to maintain runway centerline after rotation and during initial climbout. As long as runway remains visible and available, you should be directly above the runway in case of engine failure.
If there is a significant cross-wind, enough to seriously cause a dangerous side drift, the ceiling is not likely to be less than 400 feet, nor vis less than 1 mile, so the departure is very likely to have runway visual after liftoff and approaching departure end where a heading is safe and where ATC intends it to be.
Hi!
I was just reading about ODPs and SIDs the other day-thanx for the info!
In the plane I fly now, it doesn't matter because of the performance, but if I rent a 172 or something I'll do the ODP/SID and be covered.
cliff
LRD
