I've heard of the same demo. I've never seen it.
On the turbine drom we have a -45R. To secure it overnight, an eyebolt is installed under the spinner and just aft of the spinner. a collar made of thick webbing with a clip goes around the prop, and clips to the eyebolt.
An individual (not me, I swear) attempted a start a few years ago with the "dog collar" attached to the prop. It bent the eyebolt severely, broke the clip, and tore the webbing...something like two thousand pound test webbing. The prop still turned.
I've been tossed aside doing differential compression tests before on large engines with big props. Even with 80 pounds of air or less in the cylinder, and only one one, the prop can have some push to it once the cylinder comes off TDC.
Even at low idle, the PT6 still has enough torque to move you.
