glasspilot:
I may have spoken too soon about not personally logging any "sole manipulator" time as PIC. I broke out my old Navy logbook and find that it doesn't even have a column for "Aircraft Commander" time, just "first pilot, second pilot, and special crew time. Most employers consider first pilot time to be the same as civilian PIC time. We had an Aircraft Commander block on the paperwork turned in at the completion of the flight but it wasn't entered into individual logbooks. First Pilot time was given to whomever was flying the airplane in theory, in practice it was usually split 50/50 between the Aircraft Commander and the Co-Pilot. The bottom line is there is no way other than an unreliable memory to separate the real PIC time from the "sole manipulator time. Therefore, you'll need to reject for employment every ex-Navy and Marine pilot with multi-crew time if you're going to be consistent in applying your personal standards. I have no idea how the AF and Army logs time, or even how the Navy does it nowadays, but I suspect it will be very similar to the way described.
