Results of Eagle Flight 5401 Accident Investigation
T-prop
Ab Initio is the best...
Results of EGF 5401 Accident Investigation [font=verdana, arial, helvetica]NATIONAL TRANSPORTATION SAFETY BOARD
Public Meeting of September 7, 2005
(Information subject to editing)
Report of Aviation Accident
Crash During Landing, Executive Airlines Flight 5401,
Avions de Transport Regional 72-212, N438AT
San Juan, Puerto Rico
May 9, 2004
NTSB/AAR-05/02
This is a synopsis from the Safety Board’s report and does not include the Board’s rationale for the conclusions, probable cause, and safety recommendations. Safety Board staff is currently making final revisions to the report from which the attached conclusions and safety recommendations have been extracted. The final report and pertinent safety recommendation letters will be distributed to recommendation recipients as soon as possible. The attached information is subject to further review and editing.
EXECUTIVE SUMMARY
On May 9, 2004, about 1450 Atlantic standard time, Executive Airlines (doing business as American Eagle) flight 5401, an Avions de Transport Regional 72-212, N438AT, skipped once, bounced hard twice, and then crashed at Luis Muñoz Marin International Airport, San Juan, Puerto Rico. The airplane came to a complete stop on a grassy area about 217 feet left of the runway 8 centerline and about 4,317 feet beyond the runway threshold. The captain was seriously injured; the first officer, 2 flight attendants, and 16 of the 22 passengers received minor injuries; and the remaining 6 passengers received no injuries. The airplane was substantially damaged. The airplane was operating under the provisions of 14 Code of Federal Regulations Part 121 as a scheduled passenger flight. Visual meteorological conditions prevailed for the flight, which operated on an instrument flight rules flight plan.
The National Transportation Safety Board determines that the probable cause of this accident was the captain’s failure to execute proper techniques to recover from the bounced landings and his subsequent failure to execute a go-around.
CONCLUSIONS
The captain was properly certificated and qualified under Federal regulations. No evidence indicated any preexisting medical or physical conditions that might have adversely affected his performance during the accident flight. The first officer held a current Federal Aviation Administration airman medical certificate at the time of the accident; however, he failed to provide information about his medical condition (anxiety) or his use of the prescription drug alprazolam when he applied for the certificate.
2. The airplane was properly certificated, equipped, and maintained in accordance with Federal regulations and approved company procedures. The airplane was loaded in accordance with approved company weight and balance procedures. The weight and balance of the airplane were within limits during all phases of the flight.
Winds were within the airplane’s performance capabilities and did not adversely affect the flight crew’s ability to maneuver the airplane during the approach and landing as significant aircraft control authority remained.
The emergency response was timely and appropriate. The passengers and crewmembers were safely evacuated from the airplane.
At some point during the accident sequence, the captain cockpit seat failed when it was subjected to vertical loads that exceeded those required for certification.
The flight crew did not account for winds when calculating the minimum approach airspeed, and, as a result, they were not in compliance with Executive Airlines’ approach airspeed procedures.
Given the relative positions of the accident airplane and the preceding Boeing 727, the runway configuration, and the existing winds, wake turbulence was not a factor in this accident.
The captain did not properly follow Executive Airlines’ before landing procedures.
The flight crew could have completed a successful landing after the initial touchdown.
After each bounce of the airplane on the runway, the captain did not make appropriate pitch and power corrections or execute a go‑around, both of which were causal to the accident.
The captain demonstrated poor cockpit oversight and piloting techniques before and during the accident sequence.
Written company guidance on bounced landing recovery techniques would have increased the possibility that the captain could have recovered from the bounced landings or handled the airplane more appropriately by executing a go‑around.
The performance of air carrier pilots’ would be improved if additional guidance and training in bounced landing recovery techniques were available.
The aileron flight control surface position sensors installed on airplanes in accordance with Supplemental Type Certificate No. ST01310NY are unreliable, and flight data recorder functional checks every 6 months could ensure the timely identification and correction of potentiometer malfunctions and ensure that accurate flight control data are available for accident and incident investigations.
Because the first officer started getting treatment for anxiety in July 2001, he should have reported this information on his last three Federal Aviation Administration airman medical certificate applications.
Although it is possible that the first officer was impaired by his medical condition or prescription drug use, not enough evidence was available to determine whether or to what extent either factor contributed to the accident.
The pitch control uncoupling mechanism uncoupled when the airplane touched down for the third time; as a result, the pitch uncoupling would not have prevented the flight crew from controlling or safely landing the airplane.
When the airplane touched down for the last time, the vertical forces on the left main landing gear exceeded those that the gear was designed to withstand, and these excessive forces resulted in overload failure.
PROBABLE CAUSE
SAFETY RECOMMENDATIONS
As a result of the investigation of the Executive Airlines Flight 5401 accident, the National Transportation Safety Board makes the following recommendations.
To the Federal Aviation Administration:
Require all 14 Code of Federal Regulations Part 121 and 135 air carriers to incorporate bounced landing recovery techniques in their flight manuals and to teach these techniques during initial and recurrent training.
Require the replacement of aileron surface position sensors installed in accordance with Supplemental Type Certificate (STC) No. ST01310NY with more reliable aileron surface position sensors within 1 year or at the next heavy maintenance check, whichever comes first, after the issuance of an approved STC. Until reliable aileron surface position sensors have been installed, require flight data recorder functional checks every 6 months and replacement of faulty sensors, as necessary.
Conduct a review of all flight data recorder systems that have been modified by a supplemental type certificate to determine the reliability of all sensors used as flight control surface position sensors. If the review determines that a sensor does not provide reliable flight control surface position data, require that the sensor be replaced with a more reliable sensor.
[/font]
Not good.....
So who was the PF, the FO or CAPT?
How "seriously" was the capain injured? Mentioned his seat failed, was that the cause of his injuries??
from what I understand it was the FO's leg and it was first day of IOE and his second leg of the day, the Capt flew the first leg.
Question: what does the flight control position indicator have to do with this? Unless they are referring that they could get better data on the accident if they had better data flight control position.
It was his first flight OFF of IOE, and yes the captain flew the first leg. Chperplt hit the nail on the head, it didn't come out until the NTSB debrief with the fo that he was taking a prescription medication and not listing it on his medical application. The fo more or less volunteered the fact that he was taking a prescription medication.
chperplt said:
I wonder how long before the FAA charges him with falsifying his medical application.
That's been dealt with, chper.
As for the accident itself, it doesnt state much of what occured. Obviously, the captain has to fry for having inadequate supervision/control of his ship.
chperplt said:
In what manner has it been dealt with? I imagine he lost his medical immediately, but have charges been filed?
As an aquaintance of persons involved, I do know that legal procedings, etc. have been in process for well over a year.
Also, where did you guys find this info? It isnt up yet on the NTSB site. Just curious.
The prescription drug they mention is the generic name of Xanax, a medication used to treat anxiety, panic attacks and social phobias. It is also a tranqualizer and much stronger than Valium, which is similar but not as potent.
That guy must be crazy to have flown under these meds., as many OTC cold remedies are forbidden by the FAA. Let alone, more benign maintenance medications that do not alter the mind are prohibited.
According to one site, it causes memory loss, decreased motor skills and has very serious withdrawal symptoms along with addictive qualities.
MJG said:
Not good.....
FO was landing, from the simulation recreation he touched down rather smooth and somehow got it airborne again, It looked like he was a little fast. It's rather easy to get her airborne again if your not careful, especially as light as they were. CA took over, bounced once more attempted to do a go around and failed when she stalled about 20 ft in the air and the left wing dropped. Too little too late. The go around may have been successful if they had completed the before landing checklist. Which calls to put the power management selector to takeoff which, in the event of a go-around the condition-levers will automatically snap to max RPM. It was left in the cruise position. Now we are required to bring the condition levers to max rpm before landing no matter what.
From the tower controller I talked to, the last bounce went as high as the trees next to the rwy. Look on airliners.net you'll see how high that is.
The FO was just out of IOE and the CA, as rumor has it, was not an easy person to get along with and was riding the FO pretty hard on the 20 min flight.
AlabamaMan!! said:
T-PROP,
Where did you find that NTSB synopsis? I can't locate it.
They will probably post it soon. They just concluded the investigation last week.
From the video it looks like everything was fine until numnuts capytan said my airplane and the thing took off again.
If somebody would've just closed the power levers the first OR second time around, there would've been lot less paperwork. FO's - you haven't felt joy until the captain takes the controls from you and then promptly fcuks both parties. That is a precious moment.
I agree with the last two posts. Although it's difficult to tell from the animation, it definitely does appear that if the captain had left well enough alone, everyone would have walked away from just another less-than-stellar landing.
Having flown in both seats myself, I'm going to go further out on a limb here and say that captains who ride FOs like this guy often are not very good pilots themselves (domineering, yet insecure and/or inept -- a very bad combination), and ought to think twice before taking the controls away from the FO at high speed and close to the ground.
I couldn't help but notice the nonstandard callouts might have contributed to the accident.
"Your power in a little bit."
"Get the power"
What does that mean?
"Add power." "Reduce power." That's a clear instruction.
"Get the power" is about as ambiguous as you can get. A guy on his first trip off IOE might not have any idea what he wanted.
The plane was on the ground for a good 3-4 seconds and didn't loose any speed. Looks like the FO never brought the power to flight idle. And he was about 5-10 knots fast too.
hotwings402 said:
How did they find out he was taking meds? Did he volunteer it after the accident? Geez.
Dude, they take a urine and blood test after ANY accident to see whether you are under the influence of any drugs or alcohol. Very unlikely he would volunteer such information. It's a very powerful sedative, and should not be taken while flying.
Depending on the medications half-life, it can be detected for several days after being taken. It does not necessarily have to have been taken that day either. For those of you wondering, all medications have published half-lives. For instance, if a drugs half-life is say, 12 hours, then after 12 hours of ingesting the medicine, half of it is excreted from the body. 12 hours later of of the remaining is excreted, and so on. As you can see, the more days that go by, less and less is removed.
Take 20mgs.
12 hrs./10mgs.
24 hrs./5mgs.
36 hrs./2.5mgs. remains in system...
FYI, I used to work in a mom & pop pharmacy part-time while in school. Learned a lot and actually got to fill prescriptions....:)
Thats true, I'm sure theres alot of guys on this board that have had anxiety at some point or even depression but please guys don't take this stuff while flying, its probably worse than drinking and flying.
I agree.
Mmeds. are just a crutch. Don't solve anything except band-aid the problem. You need to find out whats causing these things.
One post mentioned that it was his first day off IOE and with a difficult captain. I can see why he may have wanted some chillout pills!:)
I noticed from the video the CA told the FO that they were gonna balloon, yet they were still pretty far out from the threshold and 1,000 marker. He also told him not to pull back or flare, I guess so that it would prevent against any ballooning. But at the speed they were at, I think if he began his flare they might have floated a little bit, not balloon. I don't think it they were set up to balloon at the speed, height and distance from where it was called out.
[font=verdana, arial, helvetica]SAFETY RECOMMENDATIONS
[/font]
Now that sounds like fun - would that involve some practice in the sim? ;-)
Here is another reason why you don't take drugs and fly. People die.
http://ntsb.gov/ntsb/brief.asp?ev_id=20010816X01703&key=1
The toxicological examination revealed that 0.049 ug/ml of codeine, in conjunction with 1.658 ug/ml of morphine, was detected in the pilot's urine. Morphine is an inactive metabolite of codeine. No codeine or morphine was detected in the pilot's blood. Codeine is a narcotic painkiller, used for control of moderate to severe pain. Codeine is found in various prescription painkillers, as well as in some over-the-counter cough suppressants.
Additionally, the toxicological examination revealed that 0.355 ug/ml of paroxetine was detected in the pilot's blood, and unspecified levels of paroxetine were detected in liver tissue and urine samples. Paroxetine (trade name Paxil) is a prescription antidepressant medication commonly prescribed to patients suffering from social anxiety disorders, and panic attacks.
During a telephone conversation with the National Transportation Safety Board investigator-in-charge on January 3, 2002, the pilot's personal physician reported that he had prescribed the accident pilot's prescription for Paxil, but had not prescribed any medication that contained codeine. The physician added that he first started treating the accident pilot on May 9, 2001, after the pilot complained of ongoing chest and throat tightness. According to his physician, the pilot explained to him that he had a longstanding history of anxiety that was previously treated with other anxiety medication. The pilot told the physician that he had to discontinue use of the medication since he was a pilot.
The NTSB medical officer reviewed the medical records obtained from the accident pilot's physician, and extracted, in part, the following information.
May 9, 2001, the physician wrote in the pilot's medical records, in part: "26-year-old male comes in today for "years" of ongoing chest and throat tightness. ... He says it often comes on when there is bad weather and he has to fly, or when he has to give his briefing talk to several people." The medical records note that the pilot was scheduled for an Upper GI Series, to be conducted within the next two weeks. Additionally, the physician prescribed 10 mg of Paxil to be taken once per day, and provided the pilot with a one-month supply of Paxil sample packages.
On May 23, the accident pilot underwent an Upper GI Series examination. According the physician's notes, the examinations findings were, in part: "There is moderate large distal sliding hiatal hernia with minor gastroesophageal reflux." Additionally, the physician writes: "...He [the pilot] also says he feels slightly better on Paxil 10 mg, so tomorrow he is starting 20 mg per day. He says he'll phone when he needs more meds."
On June 19, the accident pilot visited the physician for a follow-up appointment. The physician's notes state: "... comes in with progress report on his Paxil trial... He notices that he has less anxiety while flying his plane and less subjective shortness of breath while speaking to people in the airplane. It was getting to be enough of a bother that he was real unhappy with his job. Now he says that's being reversed. ...He complained of a little grogginess upon waking in the morning, but feels that it clears rapidly and is not present at the time of his going to work. ... will increase the Paxil from 20 mg to 30 mg a day. Told him again to expect a subtle increase in his early morning grogginess. He understands that he's not to work if he feels that this is impairing him at all. I also was clear that his records would have to be surrendered if an employer requested them. He agrees and understands. He'll increase to 30 mg for next three weeks and see if he feels in optimal control of anxiety. If not, he'll increase to 40 mg and notify me - samples given today for about 6 weeks."
On July 25, five days before the accident, the pilot's physician made the following entry in the pilot's medical records: "By the way - Request for refill of samples today. Feels 30 mg is good dose of Paxil..."
The FAA's 1999 Guide for Aviation Medical Examiners states, in part: "The use of a psychotropic drug is considered disqualifying. This includes all sedatives, tranquilizers, antipsychotic drugs, antidepressant drugs , analeptics, anxiolytics, and hallucinogens." The drug Paroxetine (Paxil) is considered a mood-ameliorating drug and requires a review by the FAA's medical certification division before being used by pilots. The prescribing physician was not an FAA certified medical examiner.
Pa32-300 Accident, not ATR.
This post is in reference to the preceding one, in regards to the sight seeing pilot of a Pa32-300, NOT the ATR.
Medications also increase your susceptibility to histotoxic hypoxia. This is a condition where your tissue cells are unable to utilize the oxygen being transported through your blood for cellular uptake. Bascially, even at a relatively low altitude, someone who smokes an/or takes unapproved medications will experience hypoxia at lower altitudes. This may be well below the 12,500' threshold or the more pracitcal figure of 10,000.
Personally, he may either not have been psychologically suited to pilot a plane or he should have tried to deal with these feelings he was having through therapy. The article states that weather and flying along with the briefing casued him anxiety. This could have been treated in other ways. Maybe he wasn't confident in his IFR skills or the aircraft he was flying. Perhaps more time with a more experienced mentor in IMC could have helped. A course on public speaking or just reading and practicing your speaking skills might have helped too. Sometimes exercises in public speaking can alleviate this fear and may actually make you more relaxed overall.
