AIM does give an example of how to report leaving an altitude:
[FONT=KABKBO+TimesNewRoman,Times New Roman]
[SIZE=+1]Section 3. En Route Procedures[/SIZE]
5-3-1. ARTCC Communications
b. ATC Frequency Change Procedures.
1. The following phraseology will be used by controllers to effect a frequency change:
EXAMPLE-
(Aircraft identification) contact (facility name or location name and terminal function) (frequency) at (time, fix, or altitude).
NOTE-
Pilots are expected to maintain a listening watch on the transferring controller's frequency until the time, fix, or altitude specified. ATC will omit frequency change restrictions whenever pilot compliance is expected upon receipt.
2. The following phraseology should be utilized by pilots for establishing contact with the designated facility:
(a) When operating in a radar environment: On initial contact, the pilot should inform the controller of the aircraft's assigned altitude preceded by the words "level," or "climbing to," or "descending to," as appropriate; and the aircraft's present vacating altitude, if applicable.
EXAMPLE-
1. (Name) CENTER, (aircraft identification), LEVEL (altitude or flight level).
2. (Name) CENTER, (aircraft identification), LEAVING (exact altitude or flight level), CLIMBING TO OR DESCENDING TO (altitude of flight level).
NOTE-
Exact altitude or flight level means to the nearest 100 foot increment. Exact altitude or flight level reports on initial contact provide ATC with information required prior to using Mode C altitude information for separation purposes.
[/FONT]
Given, this is in the "Frequency Change Procedures" section, but it provides an example of how to report "leaving" an altitude.
I see that 5-3-3-a-1 can be interpreted in two different ways. When an instrutor pointed this out to me years ago (when I didn't include the vacating altitude in my readback), he showed me 5.5.3 in the AIM, and I interpreted it to mean that you had to include the altitude your were vacating. Afterall, that is the reason for the additional report in the first place, so why wouldn't you add that piece of information? However, after reading that sentence over and over again, I agree that AIM is not technically directive on HOW to make that additional report and a readback of the altitude you're vacating is not "required."
I do understand the need to declutter the radio waves in high density traffic areas with succint, to the point, radio transmissions. That additional 2 seconds of information, though, may not make a difference to the air traffic controller, but it may increase the situational awareness of other pilots in the same area. Or it may clue a controller in on an aircraft attemping to accept a altitude clearance intended for someone else.
The Air Force, on the other hand, is much more directive on what a pilot must readback. A pilot must readback an altitude (departing and assigned) when assigned an new altitude.
AFMAN 11-217V1 3 JANUARY 2005
11.7. Pilot Responsibilities.
[FONT=KABKBO+TimesNewRoman,Times New Roman]11.7.1. During Vectors. [/FONT]
[FONT=KABJNN+TimesNewRoman,BoldItali,Times New Roman]While being radar vectored, repeat all headings, altitudes (departing and assigned), and altimeter settings; and comply with controller instructions[/FONT][FONT=KABKBO+TimesNewRoman,Times New Roman]. [/FONT]
There must be a reason for that.
Thanks, all, for the good discussion on an misunderstood topic. And just to set the record straight, the guy I flew with was really a good dude and nice guy. I was just caught off guard with his interpretation of 5.5.3 and what I thought was technically correct and came to ya'll for help/clarification for my own edification. I appreciate the good comments.
Gremlin
[/FONT]
