Replacing the 727 at FedEx
time builder
The A321 holds 13 AAA ULDs. The 757-200SF we've got holds 14 AAA + 1 LD3. For the bellies, our docs show a volume of 53cbm (cubic meters), Airbus says the A321 has 52cbm. Therefore, the 757 has roughly 20cbm more volume. Total volume of a 757 is around 230cbm vs around 205 for the A321; a rough 10% difference. I've no data on payload capability for the A321, but would guesstimate at around 23-25 tons vs 28 for a (Boeing) conversion. Please note, it's of course possible to increase MTOW on the 757. I belive we can go up to 111tons on some of ours without modifications. Then again, we've got the -535C motors and I would expect a -535E4 engined version to be able to go higher still. Will give you more range most of all, as you'll be bulked-out (as an integrator) at around 25-28 tons.
I appreciate there's a 757 conversion on the market that'll give you 15 AAA positions (same as a 757PF), and therefore a further volumetric advantage.
The A321, however, is much leighter than the 757. We're talking an operating empty weight of 48 vs 60 tons! Sure, the 757 has superior performance over the A321, but carrying around those big fans with a 40k lbs capability is expensive if you don't need it. The A321 gets by with around 27k lbs.
So, if your requirement is to carry around 25 tons for no longer than around 3 hours, the A321 seems to be the better option. For longer sectors, or for sectors where performance is an issue, the 757 would be better.
I've personallly got nothing against Airbus, I'm sure they make fine aeroplanes. However, the deciding factor is not whether I personally like it or not - it's about economics.
Big Al
Airbus has never been much into the freighter market, and there havent't that many A321s on the second-hand market with a low enough price to justify a conversion program. They are starting to become available now, which is why Airbus has geared up and are starting to actively promote them. Hopefully they've listened to us last time we spoke and moved the cargo door from position 1 to 2!
Extremely nice, amazing what you can do with a bit of photoshop innit?
Is the -800 available as a freighter at all? I know the -700 is, can't remember reading anything about a -800PF or SF.
Here's our baby. Photo taken during RIAT 2005, ship flown by one of our skippers who's a former RAF Red Arrows display jockey. Impressive bit of flying that was, and many a fine beer was had that day ;)
I got this in an email today.
FedEx to invest $2.6 billion to buy, modify up to 90 757-200s
Wednesday September 27, 2006 FedEx said this week it will invest $2.6 billion to acquire and modify up to 90 757-200s to replace its 727-200 freighters.
The FedEx Express airline unit is expected to bring the new aircraft into service from 2008 to 2016.
"Compared to the 727 aircraft, the 757 has a 20% greater payload capacity and has an approximately 25% lower operating cost per pound," FedEx said in a statement. "Replacing the older 727 aircraft with the more fuel efficient and quieter 757 aircraft will have the effect of significantly reducing operating costs over time and provide better aircraft utilization efficiencies."
The company added that the program is expected to have "very positive financial benefits upon completion" and insisted its startup costs "will not materially affect earnings."
Crew bus rumors
Ok, the wake turbulence issue is real and separation will impact the inbounds to the sort.
I have heard speculation Memphis may go all wide bodies at midnight. The 757
could do other routes (hubs in EWR, AFW, IND, OAK, LAX) and day sort in MEM.
The staffing demand will still be high even with the 3 to 2 man cockpit change. The reason for the delay in the change of our trip rig is also rumored to be due to the staffing. By the time all the 57's show, the new rigs will be in place so there may be some "balance" to the crew force. We're still going to need a ton of new guys.
The 727 will be around for a while.. The last ones off the line came here only 13 - 14 years ago. There is a lot of life left in them.
The word we got during indoc last month was 727s on the property until 2011-2013.
Given, the 757 acquistion plan is from 2008-2016 it would appear the 727 retirement date may even slip slightly later then that.....which is often the case at FEDEX.
Interesting. Here's an almost identical release posted on our company website.
FedEx Invests in new Air Fleet
FedEx has announced to spend 2.6 billion dollars for the modernization of its air fleet within the next years. The company intends to buy approximately 90 airplanes of the type Boeing 757-200 and carry out modifications.
The short- and long distance aircrafts will go into service between 2008 and 2016 and replace older Boeing 727-200 models. The new planes can carry about 20 percent more payload, are more fuel efficient and thus create less operating costs. In addition to this the production of greenhouse gas can be reduced. As FedEx estimates the planed investment will not burden profits despite the costs for capital spending.
Which would co-incide with the last dates on the Mayan calender, interesting enough.
