Remember Speedbird 268???
nwa_contrails
Article from WSJ part I
After Engine Blew, Deciding to Fly On 'As Far as We Can'
Pilot-Tower Tapes Flesh Out 747 Incident That Triggered
A Controversy Over Safety
September 23, 2006; Page A1
A few seconds after a fully loaded British Airways 747 took off from Los Angeles on its way to London last year, one of its four engines erupted in a spectacular nighttime burst of flame.
The fire burned out quickly, but the controversy has continued to smolder.
An air-traffic controller watching the runways radioed a warning to British Airways Flight 268 and assumed the plane would quickly turn around. To controllers' surprise, the pilots checked with their company and then flew on, hoping to "get as far as we can," as the captain told the control tower. The jumbo jet ultimately traveled more than 5,000 miles with a dead engine before making an emergency landing in Manchester, England, as the crew worried about running out of fuel.
The Los Angeles air-traffic-control tapes, obtained by The Wall Street Journal under the Freedom of Information Act, show that controllers who saw the fiery engine failure with the jet just 296 feet in the air were immediately concerned about the flight and ready to guide it back to the airport. But the decision to return or keep flying rested with the captain and the airline. Ever since, pilots and aviation regulators have debated the decision of the pilots and British Airways. Their questions: Even if the plane was capable of reaching its destination, and perhaps legal to fly, was it smart to try? And was it safe?
The incident also focused renewed attention on an age-old issue in aviation -- safety versus economics. An emergency landing would have required dumping $30,000 of fuel, and the airline might have owed $275,000 in compensation to passengers under European Union rules if the flight was more than five hours late. The British Airways pilots' union questioned whether the EU compensation rules, only days old at the time, pressured airlines into pushing flights into risky situations. And in online discussions, pilots wondered if the three pilots might have been pressured into a risky flight to save the airline money.
British Airways says dollars played no role whatever in the decision to keep flying. It points out that the decision was legal under British regulations. A British inquiry ultimately said "no evidence was found to show that the flight continuation posed a significant increase in risk."
Flight 268 also set off a feud between U.S. and United Kingdom regulators over which nation's rules would apply. The U.S. Federal Aviation Administration, taking a different view of the incident than British regulators, opened its own investigation and then an enforcement action, charging British Airways with flying the jet in an "unairworthy condition." The FAA proposed a $25,000 fine. But last month, the FAA quietly dropped the matter rather than fight in court with British Airways and possibly U.K. regulators as well.
While 747s are certified to fly on three engines, doing so leaves much less room for error. They fly a bit slower and can't reach the highest altitudes, where thin air creates less drag, so fuel use increases by about 8%. The real risk is that if the plane should lose a second engine it would have more difficulty flying, especially if two engines on the same side failed -- leaving the thrust all coming from one angle and forcing extensive rudder use to keep flying straight. The plane would then have to fly even lower. Greater fuel consumption might mean the plane would have difficulty reaching an airport if it was over the ocean.
Flight 268's decision clearly surprised Los Angeles air-traffic controllers. The flight took off at about 9:24 p.m. on Feb. 20, 2005. Trouble was soon visible, as evident in radio discussions of "Speedbird 268 heavy." ("Speedbird" is aviation's call sign for British Airways; 268 was the flight number; "heavy" refers to jumbo jets.)
"Speedbird 268 heavy, it appears you have flames coming out of either your No. 1 or No. 2 engine," the tower controller radioed.
"We're shutting it down," replied the captain, already aware of a problem. British investigators later said passengers heard a bang when the engine failed, and some, like the tower, saw flames.
The tower controller alerted a colleague known as a departure controller, whose job was to take over responsibility for the flight as it left the airport.
"Speedbird 268 has got an engine shutdown. He had flames coming out of it. He's coming to you now. We don't know what he wants to do. We know he wants to come back, probably." The departure controller told the crew to climb to 5,000 feet and advise him of their intentions.
Pilot: "Roger standby. Climb and maintain 5,000. We are able. We will advise. We had a surge on takeoff and we're just doing the checks."
Departure controller: "Speedbird 268 heavy roger. Tower said you had flames coming out of the engine and it was shut down. Is that accurate?"
Pilot: "We haven't shut it down. We've throttled it back and we are doing our checklist."
The departure controller asked for the number of people on board -- standard procedure in an emergency in case there is a crash. It was 351 passengers plus 18 crew members, the pilot reported.
He next told the controller, "We have now shut down the No. 2 engine. We are going to consult our company and see what they require us to do."
After making four more 90-degree turns, and sending a co-pilot back in the cabin to look out the window at the engine, the captain said: "We just decided we want to set off on our flight-plan route and get as far as we can. So we'd like clearance to, ah, continue our flight plan."
The controller gave the captain clearance to a higher altitude. But when he called other controllers to make arrangements down the line on an internal intercom system, surprise was evident.
"Remember that Speedbird I told you about?" the controller asked a colleague.
"Yeah."
"He's engine-out -- No. 2 engine out. He's going to continue to his destination or as far as he can get," the departure controller said.
"OK. I have no flight plan on him." The tapes show the controllers had assumed the pilot wasn't going to London, so they deleted the flight plan from the computer. To reconstruct it, the departure controller called the tower.
"Is he going?" the tower controller who had seen the engine flames asked.
"He's going," was the answer.
"If you would have saw what we saw out the window, you'd be amazed at that," said the tower controller.
As the flight moved east, the departure controller passed the pilot on to another controller. "Thanks for your help. Cheers," the captain said. "Good luck," said the departure controller.
The plane flew across the U.S. at a lower-than-usual 27,000 feet and a speed about 12% slower than normal, according to the British investigation. Hours later, the captain made a final decision about crossing the Atlantic. "Having reached the East Coast of the U.S.A. with no indications of further abnormality and with adequate predicted arrival fuel, the crew decided to continue to the U.K.," said the U.K.'s Air Accident Investigation Branch in a June 2006 report. The AAIB said the casing of a component within the Rolls-Royce engine had worn out, causing a power surge, and high temperatures did severe damage.
Winds were less favorable than anticipated across the Atlantic, causing the jet to burn more fuel than predicted. In addition, the crew became alarmed that they might not be able to access the fuel in one of the four wing tanks. The captain declared an emergency and landed in Manchester. The British investigation later found he would have had enough fuel to make it to London.
After the landing -- uneventful but for fire trucks on hand -- controversy arose among pilots. U.K. and U.S. agencies both opened investigations. Britain's learned that British Airways had flown 747s to distant destinations on three engines 15 times since April 2001.
