gcaflyer said:Last I read they were at 137kts when they exited the runway. Flaps 20 t/o on the 50,000# card they should have been real close to flying. I definitely wouldn't say there was no way that they could have made it.
svcta said:Last time I flew a CRJ we were using flaps 8 every chance we got(as a policy); kept more air moving throught the powerplants @ rotation because of the higher speeds. When that thing was heavy and you were flexing I remember rolling for about 2 days before V1. I recall burning up 5 or 6 thousand feet pretty easily.
j41driver said:Unfortunately I don't think that a CRJ200 with 50 people on board would take off from a 3500' runway even if you firewalled the power from the start of the takeoff roll.
Hawker dude said:You sir, are a dork.
That's pretty surprising. No change in thrust? They must not have seen it coming.pilotdiscretion said:The engines were set to 90% N1 and stayed that way until the FDR stopped recording. In order to use a BFL of 3500' the CRJ 200 would have to weigh 33,000.
Black Hawk said:That's pretty surprising. No change in thrust? They must not have seen it coming.
Sam Snead said:I don't think the pilots' response to the 'we're out of runway' problem would have caused either of them to firewall the thrust levers.
My reasoning is that the only non-FADEC simulator scenario that calls for 'radar power' is windshear.
Unfortunately, confusion probably reigned as the airplane went from asphalt to grass. My guess is that they only realized there was a problem when the wheels started rumbling over the grass. Given the lighting conditions and the circadian time of day, they didn't see the red end lighting, or if they did they did there was little or no deceleration.
This all assumes the CRJ model in question is non-FADEC. Anyone?
I've made bigger mistakes but been a lucky SOB.
PURPLEHAZE21 said:Guys,
Were talking about Lawyers.......Don't get sucked in to the Vacuum !!!!!!!!!
I've been saying for years we are inadequately trained for various extreme emergencies.Huck said:Over at PPrune there is an old dude that said this: he had a sim instructor that used to pull another aircraft onto the runway when they were about V1 - 10 on the takeoff roll.
The instructor taught them to slap down full flaps. Their aircraft would balloon into the air and barely climb, but they would make it.
Sounds silly, but when you've run out of all other options....
surplus1 said:I've been reading, and reading, and reading, and I've seen all sorts of hypotheticals about how this might have happened.
I heard the NTSB peson say (on TV) that there was verbalization between the pilots about the runway lights being out.
But, no where at anytime have I seen anyone of you pilots question or comment about why this airplane was taking off on an unlighted runway.
I have to ask: Is that something that you folks consider as a "normal" thing you do? A routine operation?
surplus1 said:Somebody please reply to #52
172driver said:I believe the CVR reflected that they commented on the lights during the t/o roll, not before, as you would expect if the rwy had appeared to be unlit. That's my take on it.
Gorilla said:I hated the MD-80 for this very reason. The 737-800, and most Boeings, are great in this regard. Slam 'em to the stop, no worries.
Where did you read the CVR transcript?
