dmspilot00
Independent
- Feb 22, 2002
Rush Limbaugh said:"N345 is not my tail number!"
It is if you are flying an airplane registered in the United States.
Umm, no its not
dmspilot00 One other thing. If I tell ATC I am "Cessna 12345," why do they sometimes call me "November 345?" It should either be November 12345, Cessna 12345, or Cessna 345, or just 345.... not N345. N345 is not my tail number! It just doesn't make sense.
There is no difference. They're equally annoying.dsee8driver said:I cannot see a difference between "Citation123 checking in at FL310" and "Citation 123 with you at FL310."
dsee8driver said:DMS...I think you should read the AIM under communications and phraseology. You yourslef say it should be November 12345, well guess what ATC can and will shorten it to N345 and it's perfectly legal.. Maybe ATCER can add to this ....
I had this one student, a young lady who couldn't get it into her head that a degree of formality was required in aviation communications...Yahtzee said:I can't begin to describe how bad the radio calls from students can be...
ms6073 said:I cnat believe nobody has mentioned...
Regional Approach: Cessna 12345, say intentions?
Student Pilot: Yes, I am wanting to become an airline pilot!
TXCAP4228 said:How many times have you called approach, told them who, what and where you were and said you had whatever current information is on the atis, only for them to call you back and say: "so and so, say aircraft type and altitude and advise you have whatever information"? Drives me nuts.
And while I am talking about ATC....
I also had an approach controller forget I was IFR recently. It was late and the tower was closed at the field I was going into to and after he told me to squwak VFR and frequency changed approved I said I'd go ahead and cancel - he says "Uhh... oh yeah, I forgot about that. Cancellation received."
Does that happen very often?
dmspilot00 said:One other thing. If I tell ATC I am "Cessna 12345," why do they sometimes call me "November 345?" It should either be November 12345, Cessna 12345, or Cessna 345, or just 345.... not N345. N345 is not my tail number! It just doesn't make sense.
StarChecker said:I also don't understand how 2-person crews with top of the line avionics packages, autopilots, FMC's, blah blah blah....can miss radio calls when one person's main function is the radios. I know you have to talk to dispatch and ramp control. I fly every night and never hear a Starcheck flight miss a radio call, and we're doing it all; with a fraction of the automation and half the crew.
Actually heard it happen at VRB:StarChecker said:I love the corporate guy...who, upon arriving at the end of the line of 4 other airplanes ahead of him for takeoff, tells the tower he's "ready in sequence." My god, what do you THINK he's gonna say?
It's usually 757's and 767's that are doing it to me. And I'm not talking about aircraft that are taxiing, I mean guys who are facing me, holding short of the opposite side of a runway, not going anywhere! My policy is that the guy gets two warning shots from my taxi lights. If he still hasn't gotten his lights out of my face, I turn on all of my forward-pointing lights and leave them there.....there's no reason for your Cherokee to be taxiing around in the middle of the day with every possible exterior light on.
Then apparently you don't listen too well either!I also don't understand how 2-person crews with top of the line avionics packages, autopilots, FMC's, blah blah blah....can miss radio calls when one person's main function is the radios. I fly every night and never hear a Starcheck flight miss a radio call [emphasis added]...
