R.i.p.
propilot
Go Sioux!
Rip
For the UND guys and gals on here in case you hadn't heard. Alumni and Fraternity Brother(DTD)...
Elliot D. Dewey
[url="http://www.legacy.com/images/General/NoticeGuestBookButton.gif"]http://www.legacy.com/images/General/NoticeGuestBookButton.gif[/url] Dewey Elliot D., age 25, recently of Los Angeles, CA, formerly of Minnetonka, MN. 2004 Graduate Commercial Aviation, University of North Dakota. Died on 9/11 in an aircraft crash while in a training flight after the aircraft experienced mechanical failure. "Absent from the body is present with the Lord." Survived by Mom & Dad, Cherry & Don Dewey of Victoria; siblings, Ryan, Joel, Elise; uncles & aunts, many friends. Visitation Fri., 6-8 PM Ridgewood Church, 4420 County Road #101, Minnetonka, MN (952) 474-0858. Memorial Service Sat., 10 AM, Ridgewood Church. Memorials preferred to Mission- ary Aviation Fellowship. Obit info albinchapel.com Albin Chapel-Eden Prairie Ralph, Jim, Dan Albinson (952) 914-9410
GINCHBLASTER said:
my condolences to his family and friends. What was the mechanical failure?
Probably this one...
** Report created 9/14/2005 Record 1 **
IDENTIFICATION
Regis#: 6565L Make/Model: C152 Description: 152, A152, Aerobat
Date: 09/11/2005 Time: 2245
Event Type: Accident Highest Injury: Fatal Mid Air: N Missing: N
Damage: Destroyed
LOCATION
City: LAKEWOOD State: CA Country: US
DESCRIPTION
ACFT ON DEPARTURE, REPORTED POOR CLIMB PERFORMANCE, REQUESTED TO RETURN TO
THE AIRPORT, CRASHED 1/2 MILE WEST OF THE LONG BEACH AIRPORT, THE TWO
PERSONS ON BOARD WERE FATALLY INJURED, LAKEWOOD, CA
INJURY DATA Total Fatal: 2
# Crew: 2 Fat: 2 Ser: 0 Min: 0 Unk:
# Pass: 0 Fat: 0 Ser: 0 Min: 0 Unk:
# Grnd: Fat: 0 Ser: 0 Min: 0 Unk:
WEATHER: NOT REPORTED
OTHER DATA
Departed: LONG BEACH, CA Dep Date: Dep. Time:
Destination: LONG BEACH, CA Flt Plan: Wx Briefing:
Last Radio Cont:
Last Clearance:
FAA FSDO: LONG BEACH, CA (WP05) Entry date: 09/12/2005
2 Die as Plane Crashes Soon After Takeoff
Single-engine aircraft leaving Long Beach Airport plunges into a nearby parking lot and catches fire.
From Times Staff Reports
A single-engine airplane crashed shortly after takeoff from Long Beach Airport on Sunday afternoon, killing both men aboard, authorities said.
The plane crashed at 3:44 p.m. into the rear parking lot of an industrial building in the 3700 block of Industry Avenue, near Bixby Road, in Lakewood, airport and fire officials said. The building is across the street from the airport.
The identities of the two men aboard the plane were not released Sunday evening.
Airport spokeswoman Sharon Diggs-Jackson said she was not aware of any damage to buildings or property on the ground.
But Jeff Reeb, a battalion chief with the Long Beach Fire Department who responded to the crash, said one car was damaged.
Reeb said the plane came down at a "rather steep angle" when it crashed and caught fire.
Authorities did not immediately know the cause of the crash. The National Transportation Safety Board has been called in to investigate.
Weather is not believed to have been a factor because there was no cloud cover or rain at the time the plane took off.
Firefighters from Long Beach and Los Angeles County responded to the scene and quickly put out a small fire, said county fire dispatch supervisor Art Marrujo.
A passerby, Brent Hatcher, 17, said he was walking with his friends to an arcade when "we saw a big cloud of black smoke."
"They put it out real quick," he said.
NTSB releases prelim:
NTSB Identification: LAX05FA296
14 CFR Part 91: General Aviation
Accident occurred Sunday, September 11, 2005 in Lakewood, CA
Aircraft: Cessna 152, registration: N6565L
Injuries: 2 Fatal.
This is preliminary information, subject to change, and may contain errors. Any errors in this report will be corrected when the final report has been completed.
On September 11, 2005, about 1545 Pacific daylight time, a Cessna 152, N6565L, collided with terrain at Lakewood, California. Aviation West Flight School was operating the airplane under the provisions of 14 CFR Part 91. The certified flight instructor (CFI) and the student pilot sustained fatal injuries; the airplane was destroyed. The local instructional flight departed Daugherty Field, Long Beach, California, and had been airborne about 1 minute. Visual meteorological conditions prevailed, and no flight plan had been filed. The approximate global positioning system (GPS) coordinates of the primary wreckage were 33 degrees 49.79 minutes north latitude and 118 degrees 976 minutes west longitude.
According to the Federal Aviation Administration (FAA), the airplane departed runway 25 right at Daugherty Field. About 30 seconds later, the pilot reported poor climb performance, and requested to return to the airport.
Numerous witnesses observed the airplane. They reported that it was low, and appeared to be going slow. The engine maintained the same sound; it was not coughing, sputtering, or backfiring. It sounded like it was at a low rpm (revolutions per minute). They reported that the nose was up, the wings were rocking, and the tail was moving back and forth. The right wing then dropped about 90 degrees, and the nose went nearly straight down.
The airplane came to rest behind a building. The right wing was under a truck, and the truck's front left wheel was on top of the right horizontal stabilizer. The right side of the fuselage and the vertical stabilizer rested against the truck's front bumper. Fire consumed most of the cabin area.
From the NSTB prelim that FN FAL posted:
" It sounded like it was at a low rpm (revolutions per minute)."
What's the point of using acronyms if you're going to write it all out anyways?
MDAutry said:
Was it in a spin?
It's easy to be the monday morning quarterback but it sounds like a spin. You can't turn the plane around if its too low. Even if all thats in front of you are buildings and crowded roads you still cant turn the airplane around at low altitude. I'm not saying that I could have done any better. It's just sad to see the same mistake repeated over and over usually resulting in death. I try and tell all my students: 300' from pattern altitude make your crosswind turn. OH, and by the way this is when its safe to turn back to the runway. Until then its straight ahead and aim at the smallest tree.
Fly Safe
Fly Safe
Not all aircraft can make it back to the runway at 500 or even 700 feet AGL. If I'm on my game and have practiced the 'impossible turn' recently, I can make a 172 or a Warrior back to the departure runway at 700'. Most of the time it's 800' AGL before the attempt will become successful. If one has a high performance single, forget it, the numbers increase to 1000' or more before the turn back to the field, even the 180 turn to land on the taxiway or the grass is iffy.
I lost 6 friends on December 23, 2004 to the impossible turn. The pilot (my friend, mentor, and an excellent flight instructor) knew better, but tried it anyways.
Something my Dad told me when I was learning to drive applies to engine failures after takeoff in singles: "When crashing, aim at the softest, cheapest thing possible."
Fly SAFE!
Jedi Nein
He was a good kid. One of my good friends was his roommate and called me to tell me what had happened. We all went to school together.
Fly SAFE!
Jedi Nein
First off I dont want to change the subject here. Its a tragic subject but maybe we can take something away from this and learn something. I do have a question for you: How would you safely teach this to a student? You cant really pull the engine on the departure leg. Not to mention at an airport with a tower. Its hard to drill this into a student without practice. I've found that I never really learn anything until I do it myself at least once.
I was mostly refering to 4-3-2 c. 6 of the AIM when I mentioned 700 AGL. I know there isn't a real set altitude. I still remember when my instructor pulled the towrope during my pre solo glider checkout at 200 feet.
I almost got buggered up twice in 152's that had mechanical failures.
One was a mag that became ineffective after it was too late to set the plane down on the runway and one that had a mixture lever fail somewhere between off and full on.
They might be simple planes, but their lack of instrumentation makes them more dangerous in my book.
Before I get attacked on the mag one...I know, no instrumentation will help you there. However, a fuel flow gauge or an EGT guage would have helped me figure there was something wrong in the mixture incident.
Let's not jump to conclusions on this pilot, but let us reflect on our own flights and future flights we may embark on. I'm not saying speculation is off limits, but don't beat on the decedent. He did the best he could with what was dumped on him.
One advantage of flying radio control for many years, and especially with the heavier models such as quarterscales with high wing loadings; was a lot of first hand looks at the result of departure stalls, 180+ degree return to the runway stall/spin scenarios, turn to final cross-controlled stall/spin & accelerated stall/spin.
This is experience with out actually being on board, but the results are the same, and it stays in your mind.
