• NC Software is having a Black Friday sale event November 26th thru 29th. Use coupon code BF21 at checkout to take 15% off your purchase for eligible products. Visit https://nc-software.com to shop now.
Question regarding smoke in cabin
NEDude
yada yada yada
Total Time
6000+
A quick survey for all of you.
Why do most checklists (at least the four aircraft I have been typed on) ignore cabin O2 for pax with regards to smoke or fire?
What are your thoughts on this, do you provide O2 for the pax if there is smoke or not?
I know my answer but do not what to skew responses. What do you folks do/not do and why?
Yes, there are a bunch of us bored at the crashpad right now.
PS- Any references would be welcome as well.
dhc8fo
Total Time
lots
My checklist addresses the pax in the non-memory portion. Granted it takes them a little longer to get O2, but it is obvious why we need it first.
NEDude
yada yada yada
Total Time
6000+
Clarification - On follow up items there is some mention of pax O2 for some of the aircraft we have researched, but only after smoke has been eliminated (ie depressurization to ventilate the aircraft).
Daytonaflyer
Total Time
000000
Nope, not if a fire is suspected. Adding O2 to a fire could turn it into an inferno. If the fire is completely extinguished, then yes, O2 is okay for the pax.
GogglesPisano
Pawn, in game of life
Total Time
enough
I agree with Daytona (so does Boeing and Delta.)
Smoke in the cabin = Do not deploy pax O2.
SkyWestCRJPilot
Now a CAL FO
Total Time
8500
The passenger oxygen masks have re-breather bags that mix ambient air. If there is smoke in the cabin then it mixes with the oxygen the passenger is breathing doing more harm than good. Plus what another poster said about not adding more oxygen to the fire in the cabin.
stall022
Total Time
10,000
Passenger oxygen generators do not provide the positive pressure to keep the smoke out of the cup, so people would be breathing oxygen smoke. They will also be providing a fresh oxygen and heat supply to a fire.
CA1900
Big Member
Total Time
11000+
The main reason is because the oxygen masks that passengers use mix ambient (smoke-filled) air in. They won't help, and will in fact make things worse than simply covering the nose and mouth with clothing, which can help filter the smoke somewhat.
If they had the type of masks we have up in the cockpit, that would be a different story, but they don't. Those masks are really only useful for a high cabin altitude.
Also, as Daytonaflyer points out, starting up a bunch of oxygen generators would be a really bad idea when there's already a fire.
I don't have any references handy; the only thing I could find is this Wikipedia page, but I don't feel Wikipedia's a reliable reference.
ImbracableCrunk
Unregistered Un-User
Total Time
6AM
As opposed to breathing smoke and smoke?
Are the masks only to be used to prevent hypoxia?
Here's a question that I wanna know - Do the hoses extend far enough that you could be on the floor and still have the mask on?
ImbracableCrunk
Total Time
6AM
Ahhhh, I see what ya did there. You answered my questions 4 minutes before I even asked them!
ron burgundy
Total Time
12000+
or if you are riding in the back, you could pop the psu open break off the bag and mask and suck on the tube for o2.
erj-145mech
Total Time
1350
And how are you going to "pop" the psu open? Have you ever seen the latches on the psu doors? All you are going to do is hyper ventilate and pass out attempting this.
All the oxygen generators are going to do is sustain life from the higher altitudes down to about 14,500. Thats all they were designed to do.
You're best bet is to grab one of the flight attendants walk around bottles, they have about 1800 psi in them.
75M
Total Time
9000+
Yeah, pressing a paperclip into that little hole must be exhausting!
Bako Cap
Total Time
10500
Or you could use a bobby pin.
"Where am I going to find a bobby pin?
Out here,
In space?"
NEDude
yada yada yada
Total Time
6000+
Thanks for the responses guys. Heard all of that stuff as well. A guy in the crashpad got chewed out at his last checkride because check airman insisted that you should put out masks in the event of cabin smoke to "at least give the passengers a chance". Apparently the check airman even got a little personal.
Just goes to show that being a check airman doesn't always mean you know what you are talking about.
NJAPLT
Total Time
enough
When I worked for a commuter airline, (a 1900 so the pax can see the cockpit) they had a smoke incident around rotation, pilots put on the masks and did an immediate return. After they landed the passenger said he was going to sue, "Because the pilots tried to kill him by not giving him oxygen, after all they were wearing their masks. They never could convince the passenger that it would have made the situation worse."
