One item not mentioned here is that the flight control laws on the Bus are different from normal aircraft in one important respect. That is that the motion of the side stick is a rate command not a flight control position command. A specific degree and rate of movement of the sidestick produces the same aircraft reaction regardless of aircraft speed.
This makes hunting for the ground easier. You don't need larger and larger inputs as the aircraft slows. Very small inputs will produce the same results even as the aircraft is slowing. The flight controls, ie elevator, ailerons, will move at greater and greater deflections to produce the desired attitude change with the same relative side stick input.
If you keep this little item in mind it makes landings easier, in my humble opnion.
