Question for ASA Pilots
Can you quote the reg that supports statement #3?
Can now.
14 CFR part 121 fuel requirements for domestic, flag and supplemental:
• All domestic operations:
No person may dispatch or takeoff an airplane unless it has enough fuel
to:
1. Fly to the airport to which it is dispatched;
2. Thereafter, to fly to and land at the most distant alternate airport
(where required) for the airport to which dispatched; and
3. Thereafter, to fly for 45 minutes at normal cruising fuel consumption.
Of course this is all for planning not for the real landing.
This is a flame bait post.
Dispatchers are FAA certficated positions subject to similar exams as pilots take for certification in addition to required medicals, time and duty regs, etc.
ALL of which a dispatcher would be WELL aware of in addition to their specific company's operational policies.
D' oh!
Ok a question for dispatchers:
I am holding over ODF in a CR2 going to ATL. KCHA is the filed alternate. KCHA is is not looking that good as an alternate due to wx between me and that airport. The bug-out number that I have arrived at on this day was 4200lbs (reserve+alt+500lbs to get to ATL w/no downwind). I call flt control to see if there is a better option closer to ATL with better wx. They come up with KGSP (49NM from ODF) and a bingo fuel of 3100lbs.
Needles to say I found that number odd. I would not have found it odd if KTOC was my destination, but seeing as it is actually farther away from KATL than KCHA (40NM farther) I found that a bit off.
How do you guys come up with these magic numbers?
I was still going to divert at my number regardless unless I was heading towards KMCN, but they are things that make you go "hmm".
The oh sh!t light on on the CR2 is 900lbs. 1,200lbs for the CR7 and the ATR has a set of bicycle pedals for the FO to use to spin the props if they run low on gas.
A minimum fuel advisory should be made when it is determined that a
landing at the destination will be made with less than the planned reserve
fuel listed on the Dispatch Release
From the ASA FOM.
I understand that and correction made. However, the question was regulatory based, not FOM or recommendation based.
Can now.
to:
You need to seriously RTFQ.
The question was:
3rd. What min fuel requirements per regs do you have to land with.
The question was not "What min fuel requirements per regs do you need for reserve?" It also was not "What regulation requires you to land with reserve fuel?"
Just like the original poster stated to you before, your answer is for dispatch purposes (planning purposes) only, not for landing. Although you stated such at the end of your post, you've wasted your time.
When you were originally asked if you could state the reg that supports your answer, your initial response of "Nope" was the correct answer.
I am assuming that the dispatcher figured you would divert instead of giving you a new alternate. Alternate burn is figuring that you actually make the approach into ATL and then go missed, climb back to altitude and then divert to CHA. Divert fuel is figured as you never leaving ODF to go to ATL at all and instead diverting directly to GSP from your current altitude. Hence, the fuel burn will almost always be less. Sounds like your dispatcher gave you divert bingo fuel instead of amending your alternate.
Indeed it is, but not entirely undeserved. There are many pilots that assume their dispatcher doesn't know what he is talking about and try to claim non-existent obscure regs when they are too proud to call it what it is: comfort fuel.
See replies #12 and 13.
Yep, dispatcher realized CHA wasn't good anymore, so "go ahead and divert right now to GSP...here's your fuel numbers to GSP, you will have a new release waiting for you to come back to ATL when you get on the ground." Perhaps the "divert right now" wasn't clearly communicated.
Of course, it could just be a dispatcher that doesn't understand what/how/why the numbers are being calculated, and gave you erroneous numbers.
I always thought the best way to keep a safe operation was the captain assumed the dispatcher didn't know what they were doing, and on the flip side, the dispatcher assumed the captain didn't know what they were doing. Hopefully, if the numbers came out equal, each side knew what they were doing...otherwise they both had wrong info :eek:
D' oh!
Not flame at all. The point he was trying to make, is yes he knows the rules, it's the CAPTAINS that are telling the dispatchers that they are required to have those things. So hes trying to get a concensus on what other Cpts think are the rules.
Kind of an interesting perspective on it. I kinda do the same. I don't necessarily assume the captain has no idea what he's doing (though there are some I wonder about)...however, I can safely assume that he doesn't have the big picture I have in front of me.
I've discovered that very deliberate language must be used when it comes to alternate amendments and divert burns. I've had pilots argue with me that I was a total moron because the divert burn I gave them to the listed alternate is 1000+ lbs. less than the planned alternate fuel...however, that was not including the missed approach and climb out of that approach. Because of this, I make sure to use thos specific, deliberate words to make sure we are on the same page and no assumptions are made. In this case, if we were communicating via ACARS, it would look something like this:
DIVERT BURN FROM CURRENT
POS/ALTITUDE VIA ODF..KGSP
XXXX LBS.
DOES *NOT* INCL APPCH TO KATL
(INSERT LATEST KGSP METAR AND TAF
AS WELL AS ANY OTHER PERTINENT
INFO HERE)
Whereas, if we were amending the alternate enroute, I would send:
KCHA NO LONGER VIABLE ALTERNATE
LETS PLAN FOR KGSP INSTEAD
XX NM. FROM KATL
ALTERNATE FUEL INCL. MISSED
APPCH AT KATL COMES OUT TO
XXXX LBS.
INFO HERE...THEN ASK WHAT THEY
ARE SEEING AND HEARING)
The key here is the fact that "Divert Burn" and "Alternate Fuel" should be considred to be two different things.
Kinda like one of those things that works as it is...but would work better if it were assembled correctly. But, hey, it does work.
Wait, are we actually sharing good information and learning things on FlightInfo today? WTF? :D
The question was:
Okay, okay... you win! :0
Are you the senior JK or the junior one?
Oh hell,
Just put the fuel on you want and don't tell anyone!!
Long time told me, he does that on every flight!!!
roflmao
:beer:
