Question for Aloha guys
retard
Member
Just wondering on the weight situations for your Hawaii flights from SNA - KOA/HNL. Are they weight restricted at all?? Or can you fill 'er up? Trying to get in some R & R with the fam. Thanks for the info.
During the summer months weight restriction is not a problem. With the winter Jetstream you can run into problems taking more fuel. The loads are good but if you're traveling solo just J/S. If you'll be traveling with others maybe try the KOA or OGG flights before HNL, especially on a Monday. Good Luck
