apcooper
Dude, where's my country?
- Sep 4, 2004
If you are flying a published arrival and you are told by ATC descend via HADLY TWO arrival, for example, which alt would you go by? The MEA's of each segment, the "expect to cross at" altitudes or what? This seems pretty confusing. I think I'd just insist ATC call my descents so I don't inadvertantly bust an alt.
A second question. Looking at the MITTS TWO into LAX the chart says "proceed via rwy 25L unless otherwise told by ATC" My other question is lets say your inbound over GRAMM (PGS transition) and ATC says instead of "proceed via MITTS TWO arrival," they instead say "Proceed via MITTS TWO arriavl, expect RWY 24R"
Lets then say you don't hear anything more and the freq is busy so you can't break in to ask. Would you just consider this lost comm and therefore do the 24R transition if your in IMC (in this case "EXPECT" trumps last recieved clearance or as published) or would you still fly Rwy 25L since "expect" is not an actual clearance, yet anyway? Kinda confusing huh!!
One more scenario. After TO you are handed to DEP and are vectored for a while and then told proceed direct SBJ. You look at your chart and find SBJ VOR was not your initial fix OR a fix further down your clearance. Its not on it at all. If told to do this with no further instructions would you just hold there in a standard way and tell ATC the problem? Of course I'd just say right away "Departure, Cessna 112PF, SBJ was not on our orig clearance how about direct XXX" (the first wpt on orig clearance) If you lost comm in IMC in this situation I'd just ignore this and fly the normal lost comm routine and then call ATC after I landed and then tell them what happened. This seems like a hole in your clearance that might void it.
Like all your thoughts and opinions.
