Quality time?
hot section
New member
I am currently residing in FL but will be moving back to Madison, WI by the end of April. I have 625 TT, 162 Turbine (102 is PIC), 183 multi, and 54 actual instrument. I know that the regionals are looking for at least 1000 TT, some more than that. Should I bother sending in a resume to any companies or should I wait? Secondly, does anyone know of any good flight operations which are conducted near Madison, WI where I could work to build more time? The only place I know of that is close is Wisconsin Aviation in Madison and Watertown.
Applying to Commuters
Your turbine time and actual v. total isn't bad. How much is PIC? Turbine PIC is key.
I see no harm in starting up the commuter resume spam if you find yourself able to continue building time. Don't get your hopes up too high, though. You'll still be fighting furloughed people and people with more time than you for the crumbs the commuters are throwing out. I'd send to 135 and freight if you feel so inclined.
Lots of luck with your job search.
I've got to know - who is insuring 500 hour pilots for PIC in turbines? If this came up on somebody I was interviewing, I'd be very curious...
As a pilot who occassionally helps other pilots find insurance, I'd like to know who has underwriting standards this flexible. So please tell.
PIC in Turbine
The PIC time came from flying the PC12. I was an intern for the state of WI aviation department and flew under their part 91 ops. I had a high altitude endorsement so it was legally logged.
THe high altitude endorsement makes no difference in the legality of logging PIC in an airplane. It makes a big difference in the legality of acting in as PIC, in an airplane requiring the endorsement.
To log time as PIC, you must be rated in the airplane. An endorsement is necessary to act as PIC (different from logging PIC); however, an endorsement is not a rating, and is not required to log pilot-in-command time.
Don't build time. Build experience. There is a big difference between logging time, and gaining experience.
Bragging rights!
If my dad was a 74 box hualer and he let me fly the thing, he would have had to lock me my room until he retired.
I must say thats cool as $hit.
LR25
Hotsection--
Send out the resumes but my guess is don't expect to get called in until you have 2000 hours or so. Reading the gouges on COMAIR, I only see that number and higher getting hired right now. That should come down as the airlines slowly begin to hire again, but right now its doubtful that you would be called.
The key is to send out resumes...they won't call you if you don't. You may not have a very good chance at getting an interview right now...but the more you send out resumes the better you look to that airline. I know American Airlines wants to know that you have sent out many resumes to many airlines. They only want serious airline pilots and they feel that serious airline pilots try to get hired by any major. The point is...send send send.
PC 12
The Pilatus doesn't require a type...does it? With the high altitude endoresement you can go ahead and log that time (legally). Any time you are flying the airplane and you are rated in it(if required) part 91 then log it.
The Pilatus is a single pilot airplane so you cannot log any of the time that you were not manipulating the controls (part 91).
Send out the resumes, but, expect to answer questions about the airplane, such as, limitations, powerplant, etc.
Actually, you can log part 91 SIC time or 121 and 135 time for that matter in a single engine airplane. The reg on SIC time says something to the effect that you can log time as SIC if the aircraft is certified only for flight with two pilots or the company policies or insurance requires a second pilot.
Just to go a little further, you can't log IFR time unless you are actually manipulating the controls. You also don't have to be type rate, just current in category, class and type, and even that can be waved if you get the landings and ground school in the first 90 days.
I think that has to be one of the least rigid regs out there.
Hmmm....interesting. Do insurance companies tend to dictate minimum requirements for the guy flying SIC? It's amazing that hot section, with about the same amount of TT that I have now (at the time he started flying SIC in the PC12), was given the opportunity. I'm jealous, hot section!
I'm a programmer for a small company that flies the big boys around in Citations. Maybe I need to start talking to the pilots... ;)
SIC
SIC cannot be logged because a company requires it nor if insurance requires it.
Case in Point..the Pilatus. The Pilatus is a single pilot certified airplane.
Just because a company says you will have a second pilot in the airplane does not mean that the pilot (not flying) can log that time.
61.159 ATP requirements: a commercial pilot may credit the following second-in-command flight time or flight engineer time toward the 1,500 hr of total time
1. Second in command time provided it is acquired in an airplane-
(i) Required to have more than one pilot flight crewmember by the aiplanes flight manual, type certificate or the regulations under which the flight is being conducted.
This is what interviewers are looking for if you say you have SIC time in a turbine aircraft.
Also their are SIC requirements that must be met under FAR 61.55
Just something to look out for.
I second what 727PAA says about logging SIC time. Ignore KSU_Aviator. Despite her "superior" KSU education, she's apparently failed to do the most basic of fact checking before posting; reading the printed regs. Take a look at the excerpt from the regs that 727PAA has graciously supplied. Notice that it only refers to requirements "........by the manual, the type certificate or regulations....." not ".....by the regulations, insurance requirements, company policy, or someone's grandmother"
61.51, which regulates the logging of all SIC time, not just that for an ATP, contains exactly the same language as 61.159
It doesn't matter a bit what the company or insurance policy wants, if a SIC not required by the regulations, you can't log it.
KSU's statement that you may not log Instrument time if you are not sole manipulator of the controls is somewhat questionable also. The regulation states that you can log if you are "operating" the airplane by reference to instruments. The issue hinges on what the definition of "operating" is. Certainly in other cases, the FAA has held that an SIC is operating the airplane, even if he isn't manipulating the controls. Additionally, when the FARs mean sole manipulator, they say "sole manipulator", giving further indication that "operating" does not mean "sole manipulator" For a more in depth discussion of this take a look at this link. http://www.propilot.com/doc/logging2.html#defin It is addressed down near the bottom of the page. In absence of an FAA legal counsel interpretation specifically addressing this, it is impossible to say for certain which is the correct interpretation. Personally, I log only that instrument time when I'm the PF. I'd rather fly like someone with twice my time than fly like someone with half my time, but that's just personal preference.
As far as KSU's statement about SIC qualifications, all I can say is ...... huuhhhhh?????? Let me get this straight, you're saying that you can just hop in any transport category aircraft and legaly serve as SIC, as long as you study the flight manual, systems, emergency procedures, performance specs, limitations and all that other stuff required by 61.55 sometime within the next 3 months?????????
really????? I didn't know that the FAA recognized retroactive flight training. Does this apply to other privileges as well? Can I act as PIC of a 747 as long as I get a type rating 90 days later?
Can you actually support this with some credible source, or are you making this up?
BTW it's "waived" not waved ..... I have to say, I'm getting less and less impressed with the quality of education avaiable at KSU
regards
KSU,
So if you can't log IMC time unless you're handling the controls then that means as PNF you can't log night time either, right? Seems to me that they're both conditions of flight. Guess I better go back and delete all that IMC and night time I logged when I was an instructor. After all, I wasn't actually flying the plane.
Honestly, I really don't care how people log their IMC time, I just thought I'd open this can of worms again. It was either that or start another PFT thread and we all know how old that gets.
Cheers!
Hey Hot Section send me a private message I have some info on WisAv. I worked there as a line guy for 2 years and as a CFI for 6 months along with getting all my ratings there, not at MSN but at their Juneau FBO. I also know of a skydiving outfit near there that has 182's and if you want to build time fast you can log well over a 100hrs a month during the summer there. I may also have some other leads for flying jobs in the area.
You can log instrument and night time as an SIC, regardless of whether you are the PF or PNF. Only the PF, however, can log instrument approches or landings towards currency, since part 61 requires that you be "sole manipulator" of the controls. Incidentally, as I understand it, you could log SIC under certain conditions in an aircraft certified for single-pilot operation, like the PC-12. As a safety pilot while the PF was under a view-limiting device, for example. I don't want to get into that debate, though.
