avbug said:
ATC can clear you to any point in the national airspace system.
Not so. Did you not read the thread?
I don't think you read my post thoroughly enough.
Yes, ATC can clear you to any fix, but NO, ATC can't clear you direct to an FAF for the purposes of flying the approach straight in. Some controllers will, but theyare not supposed to. I have had to correct several controllers who tried to clear me direct to GPS approach FAFs from impossible angles (and no PT is depicted - standard "T" type).
So, according to you, I can be cleared direct to the FAF at a 90 degree angle and fly the approach straight in?
They can clear you to the fix by name, but they WILL not clear you to the FAF directly (if they are follwing their guidance). They have to give you a certain amount of distance and a certain maximum intercept angle. Look it up in the controller's handbook.
I think that you are overthinking the 'permissive' term used in the text.
Where, then, is the permissive/madatory/prohibited PT symbol on the approach plate? How is it depicted differently? Where is the regulatory and/or advisory circular guidance on when the PT is 'permissive'?
1) If an approach has only one IAF, and a course reversal is depicted, the course reversal is mandatory unless you are being vectored. If a racetrack or teardrop reversal is depicted, you must fly it as published. If it the 'barb' depiction, you may make the reversal any way you like provided it is on the barbside and within the prescribed outbound limit.
2) If an approach has only one IAF and a PT (or teardrop or racetrack) is not depicted, obviously, you can't make a PT or any other reversal. The IAF would be either an arc or a transition of some sort. The plate may or may not say "NoPT" on that route. For some readon, this varies from plate to plate and from NOS (Naco) to Jepp. Or you can get vectored.
3) If the approach has multiple IAFs, ATC may clear you, and you may request any of the IAFs available. You must fly the IAF that you are cleared to, or if ATC clears you for 'an approach' you can select your own IAF.
That said, if you fly an arc or transition, you may not make a PT unless you request and are cleared for it (why would you want to, anyway). NoPT routes mean just that. No PT is required and no PT is authorized.
