PRIA contact for TWA(American)
sean67
Can someone PM me for the PRIA contact and address for TWA(American)? Is there a central list out there for that info?I need the info for an apploication
Thanks!
Go to aapilots.com, look under the furloughed pilots link, all the info you need is there. If you have forgotten your password, it's the same as your DECS password. Good luck
I left TWA before the merger. Thanks anyway. Anybody else out there know?
I had a similar situation happen to me when I applied at DAL. One of my previous employers had shut its doors. I called my former Chief Pilot and asked if I could leave his name and address as a point of contact. That seemed to work for me back then.
In your situation you may want to call ALPA at 703-689-2270. You probably aren't the first pilot in this situation, they might be able to at least point you in the right direction.
Also, if you still have access to the ALPA National forum, post this same question there and see what the other similarly situated TWA pilots have done.
All the best and good luck
