Doc Holiday said:Check out atldc9's post. He cited a reference...I really don't see why there should be a debate.
sometimes... There are plenty of approaches that don't have IAF's or Initial segments (radar required); plenty that don't have intermediate fixes, and plenty more with no FAF (NDB or VOR on the field). The majority (not all) of intermediate segment altitudes are minimums... not mandatory.
Yeah, but neither of these things answers the original question. The original question asked for a published reference for the definition of the FAF on a precision approach.satpak77 said:My answer was the standard FAA IFR approach definition, based on the AIM and the 8083.15 handbook. In part:
AIM - 5-4-6. Approach Clearance
a. An aircraft which has been cleared to a holding fix and subsequently "cleared . . . approach" has not received new routing. Even though clearance for the approach may have been issued prior to the aircraft reaching the holding fix, ATC would expect the pilot to proceed via the holding fix (his/her last assigned route), and the feeder route associated with that fix (if a feeder route is published on the approach chart) to
the initial approach fix (IAF) to commence the approach.
FAA Controller Handbook - 4-8-1. APPROACH CLEARANCEa. Clear aircraft for "standard" or "special" instrument approach procedures only. To require an aircraft to execute a particular instrument approach procedure, specify in the approach clearance the name of the approach as published on the approach chart. Where more than one procedure is published on a single chart and a specific procedure is to be flown, amend the approach clearance to specify execution of the specific approach to be flown. If only one instrument approach of a particular type is published, the approach needs not be identified by the runway reference. An aircraft conducting an ILS/MLS approach when the glideslope/glidepath is reported out of service shall be advised at the time an approach clearance is issued. Standard Instrument Approach Procedures shall commence at an Initial Approach Fix or an Intermediate Approach Fix if there is not an Initial Approach Fix. Where adequate radar coverage exists, radar facilities may vector aircraft to the final approach course in accordance with para 5-9-1, Vectors to Final Approach Course.
