Power-On Stalls
Full power on stall in a AC560 is 29mph, would definitely be an E-Ticket ride doing one (an probably a one way ride).
I know you mean IAS, which at that pitch is unreliable, but do you mean full-power stalls are some kind of suicide ride in an 560?
You aren't going to get 29 mph at full power without a pitch way in excess of what would be safe (probably in excess of 60 degrees). You won't drop a wing when it breaks you will probably roll inverted. I also don't like the idea of being way below VMC in an 50 yr old airplane. If Bob Hoover was riding along maybe....
I'm one of the largest commander fans I know but those poor things are just getting tired. And cold-bent spars aren't standing the test of time. I'm wichoo on that one AC.
One of the purposes of stall traing is to learn to hold a constantly straight heading throughout the entry and recovery of the stall - no matter where the ball is. Just like a landing. You keep the nose pointed straight down the center line with rudder and hold the wings level with the aileron. Period. You don't give a whit about the ball.
That's how you should stall.[/quote]
I just don't think this is the best logic. True enough, light GA planes used for training, and to some extent, a 182, are difficult to stall. That being said, a coordinated ball will ward off a lot of evil things.
You think if you kept the ball centered and the wings level when you stalled the plane, it would still fly on the same heading...
As to the power setting for a power-on stall, read the Airplane Flying Handbook. Not the PTS.
The AFH is the training handbook. When you teach the maneuvers required in 61.107 or 61.127 for pvt. and comm. certs.; when you make the endorsement that "you have trained and consider him/her proficient", you are saying you have trained in all the maneuvers indicated in the AFH, not just the "snapshot" maneuvers listed in the PTS, which are specifically designed to be standardized to be evaluated. But you, as instructor, and you as a student, should be covering, as a minimum, all the maneuver scenarios outlined in the AFH.
The AFH description of power-on stalls uses the terms "full power" and "take-off power", and "climb power".
Is there anyone out there that does not want to be proficient at being in full control authority if you happen to approach a full power stall during your take-off sequence?
The allowance to use only 65% during a checkride is for those high-power airplanes that might climb a couple thousand feet in a very steep pitch attitude which would be unsafe to climb through a large piece of sky with the nose way up.
You don't need to do that in most trainers, certainly not a 152.
And even in the high powered airplane, I am going to have the student do full power stalls for his/her own personal proficiency, and also do 65% power-on stalls for the checkride.
You could use 65% regardless of the airplane it is the minimum listed in the PTS. The high performance exception is for power less then 65%.
C. TASK: POWER-ON STALLS (ASEL and ASES)
NOTE: In some high performance airplanes, the power setting may have to be reduced below the practical test standards guideline power setting to prevent excessively high pitch attitudes (greater than 30° nose up).
REFERENCES: FAA-H-8083-3, AC 61-67; POH/AFM.
Objective. To determine that the applicant:
1. Exhibits knowledge of the elements related to power-on stalls.
2. Selects an entry altitude that allows the task to be completed no lower than 1,500 feet (460 meters) AGL.
3. Establishes the takeoff or departure configuration. Sets power to no less than 65 percent available power.
So, if you're using an airplane that you have to get the nose up above 30 degrees, then you can use less than 65% - ok, since most civilian proppeller airplanes, including what we call High Performance, and most HP airplanes are in the 200 plus area, 300hp at best, that little notation isn't even in our area of consideration.
Note the reference to FAA-H-8083-3 which describes the use of full power for power on stalls.
The knowledge of power on stalls is outlined in the above referenced handbook. This includes the knowledge of full-power on stalls. As a matter of fact, the AFH does not mention 65% power.
OK. "Establishes takeoff or departure configuration".
Is that with less than take-off or departure power?
"Sets power to no less than 65%." Not to 65%. To not less than 65%.
Now, it is up to you, Mr. Instructor. Do you really think it is good for a pilot to not be trained in handling the equipment he is flying??
The PTS is not a training syllabus.
When you endorse a pilot applicant, your endorsement says you find that person competent - wait, here it is in the front of every PTS:
FLIGHT INSTRUCTOR RESPONSIBILITY
An appropriately rated flight instructor is responsible for training the pilot applicant to acceptable standards in all (bold in book, not mine) subject matter areas, procedures, and maneuvers included in the TASKs within each AREA OF OPERATION in the appropriate PTS.
ALL subject matter...with the references given for each task.
Your endorsement says you have done that and find him/her competent and proficient in all areas referenced for that task.
And, of course, the defining person is you, the CFI.
Are you really comfortable teaching only the rote minimums of the PTS, even if you are in the camp that says the minimums of the PTS are good enough?
