Does anyone have the FMS v4.0(WAAS) upgrade completed on their PL21 Hawker yet? We had it done about 6 months ago, and I can't get the Long Range Cruise LSK to appear (PERF-ACT VNAV page 2/3).
Uhhh....if you truly have WAAS then you should be able to fly RNAV GPS LPV approaches.
Inside of 2 miles from the FAF on an RNAV approach with LPV minimums, you'd get a LPV APCH (or something similar) annunciation/indication on the PFD instead of the LNAV-only GPS APCH annunciation/indication.
You might need to check your FMS and make sure it defaults to LPV minima on appropriate approaches, vs. defaulting to LNAV.
ttflyer said:My question is - does everyone else with PL21 + WAAS have LPV mins approved or not?
I think your tech rep is getting some "words" confused. I'm guessing your CL30 has Collins GPS-4000S GPS receivers. The GPS-4000S is the GPS receiver that is WAAS capable.
When we received the WAAS upgrade, it included upgrading our GPS from 4000A's to 4000S's. It also included new GPS antennas, an FMS software upgrade (v3.3.1 to v4.0), and some other changes to the FMC's hardware (the FMC's were sent out and came back with a new part number). There was also a AFM supplement added that described the SBAS operation and how to fly the airplane to LPV minimums.
During an LPV approach, the PFD diplays "LPV" at least 2nm from the FAF. The vertical and lateral deviation sensitivity then starts to continuously increase towards the MAP.
There were some other FMS operations that changed with the v4.0 upgrade. It enanble multiple "same type" approaches to a runways (ILS Z, Y, X etc.). It enabled a Temperature Compensation function for RNAV approaches. The GPS 4000S also eliminates the requirement for a RAIM prediction check during a RNAV direct routing/SID/STAR. And finally, a LRC performance function on the PERF menu.
It's pretty slick. It was not cheap.
Yup, our 2009 CJ2+ was delivered in Wichita with WAAS LPV capability.
When you say tech rep, are you referring to Bombardier or Collins? I cannot believe a $20M+ supermid that allegedly has WAAS capability isn't able to fly LPV.
The 750/800XP/850XP/900XP were the first HBC product to get the LPV approval in 3Q 2009.
