pilotyip
- Nov 26, 2001
The way I did it
Dangercat there are many ways to skin a cat, you have your way which you feel is the only way anyone should do things. "The way I did it". I do not agree with you, if my grandson elected to pursue a pilots career, I will recommend he not go to college full time, but follow the other time tested path where I have seen too many people succeed. That is fly full time, do your degree on the side, build time, build your resume. I will not debate the fall back value of a college degree, as I have stated many times it is nearly worthless after not being used for 20 years. Here are some of the latest Air Inc hiring stats for the Kit. Percent with no 4-yr degree, AirTran 12%, CAL 9%, DHL 33%, Jet Blue 18% and SWA 7%. Are those not good jobs? In addition, to take this one step further if 95% of the pilots applying have four yr degrees and those airline hiring non 4 yr degree pilots in the 7% to 33% range. It would tend to support that the degree is not all that important in getting a good airline job.
