PDT reduce fleet, furloughs in the future.
What a freakin' peach she is to this day, lemme tell you.
Sig,
She wasn't much of a bargain while I was there, either although it was in much better shape than 909. Do you happen to know how many cycles 906 has and it's total time ?
PHXFLYR:cool:
There was always one of those SOB's I always landed a lot worse than the rest. 908 or 911 rings a bell........
I wouldn't worry too much about getting consistently good landings . One of the senior SBY guys(since retired) would tell me when he saw me get ll p/o'ed after another less-than-flattering ..er...um.."arrival"...;:blush: "sometimes you land the dash 8 and sometimes the dash 8 lands you" Truer words were never spoken,at least when it came down to me and my severe lack of aeronautical prowness
PHXFLYR:cool:
If I remember correctly 906 got some "new" seats that you can adjust...908 on the other hand....well that planes a different story.
if they are the seats that are bolted at 90 degrees with 1/2 inch plywood seat bottoms they are from 2 of the allegheny planes that went back before the merger. people would complain and write them up and they would remove and swap them with seats from another dash then put the crappy seats back in another dash. then the cycle would start again, crews would write them up and so forth, as if we wouldn't notice the crappy seats showing up in another aircraft.
Last time I sat in thoes seats they were in EI-CHP and EI-CBJ. Before that it was 820 and 819.
Sig,
IIRC it came out of heavy check a couple three months ago and it had 68000 cycles on it.
68,000 cycles ???? Wow.....!!! Pretty impressive. I guess the total time should be pretty close to that figure. They find anything out of the ordinary as far as the airframe and structure was concerned ?
PHXFLYR:cool:
Nope, they're trying to write the book for a maintenance schedule for Dash's up to and exceeding 100,000 cycles. Can you effing believe it???
Why, yes. Yes, I can believe it.
There will be Dash 8s grinding around with revenue passengers when cockroaches inherit the earth and use my Glock as siege artillery against each other.
