HappyFlying
Cessna 150 Captain
- Mar 18, 2002
Joseph II,
I can't answer all your questions but I can tell you that a 150/152 at your elevation would be a bad choice. I have flown mine with the density altitude around 6000' and it was frightening. It will not climb. I took off that morning with a 3500' DA and when I landed I for fuel, I tied the plane down and took a long nap in the FBO until it cooled down that night. There is no way I would even attempt to fly it in Colorado. You can get away with flying in high and hot in some airplanes that have power to spare but not in a 150/152. I'm glad that I live at 1500' MSL in good ole Tennessee so I seldom have to worry about density altitude when I'm flying by myself. I still have to consider it in the summer if I have a passenger.
Unfortunately your location will be a limiting factor in your choice of airplanes. There are 150HP 150s out there but they are priced pretty close to a Skyhawk. I've flown a couple and loved the performance. If you can find one, that might be a good pick. I checked on insurance two years ago for having my little brother learn to fly (and solo) and it was going to run me over $4000 annually. I understand that everything has gone up since then. As far as the hail, it is always a gamble. Mine is on tie down because I can't get hangar space but I pay the 30 bucks a night to get it put in the corporate hangar when a nasty line of stuff is likely to gallop through.
I hope this helps,
HappyFlying
I hope this helps,
HappyFlying
