Apparently I can't use the quote features, or any of the other toolbar items...I don't know why. However...Quote:""Actually AB, it does mean I have to reach 2500' before I have my ATC clearane, just like a clearanc limit. Since ATC cannot give you a "pop up" clearance at an altitude below their MVA for that area. ''' End QuoteThis is incorrect. ATC can give you the clearance on the ground, below the MVA, below radar coverage, and give you a clearance void time.The clearance as you've provided it is a clearance to the destination, direct. That's why you said, cleared direct destination. That you were told to maintain own terrain until 2,500 doesn't negate the fact that you've been cleared. If you weren't cleared, you would have been told to expect a clearance upon reaching 2,500. Instead, the clearance you provided, clearly stated that the flight has been cleared...you've already received the clearance. There's nothing in the wording you provided that would indicate or mean anything else.I've picked up clearances many, many times, out of radar coverage. I'll get a clearance void time, and then check in with ATC in the air. Until I get radar vectors in flight, or am radar identified on part of my cleared routing, I'm responsible for my own terrain separation.The truth is, no matter who identifies what, you're always ultimately responsible. At the end of the day when you're oozing off a rock and slowly freezing to a little red icicle, it's the controller who goes home to feed the dog, and you that becomes dog food. You're always ultimately responsible for your own terrain clearance, no matter what's handed you by ATC.
