Quote:XYZ maintain own obstruction clearance to 2500 feet, cleared direct, sqauwk XXXX.Basically, it meant we were cleared direct and given an IFR clearance once we reached 2500 feet. UnquoteNo, you already have your IFR clearance in this case. You're cleared IFR, but must maintain your own terrain separation to 2,500'. You're making the assumption, with the clearance as you've given it, that you're not cleared IFR until reaching 2,500', but that's not what you posted. In the case of what you posted, you're cleared IFR, direct destination, but must maintain own terrain separation to 2,500'. In this case, you do not need to remain visual; you can enter the cloud, so long as you can ensure terrain separation by any number of means. All this indicates is that you're the one who is responsible. Clearly, ATC has told you ATC will not be responsible. Never the less, you are cleared IFR, destination direct.
Seems the board still needs some tweaking. Most of my "buttons" don't work.
