NWA had same problem as AF 447
Going2Baja
Below is an email I received last night from a friend, I changed names to initials for privacy. VERY interesting read!
From a retired NWA buddy of mine
This from B.S., a friend and NWA pilot I flew the B-757 with out of our Tokyo base.........Now obviously on the A-330
[FONT=arial,helvetica]Well, I'm sure you have all heard of the Air France accident. I fly the same plane, the A330.
[/FONT]
Yesterday while coming up from Hong Kong to Tokyo, a 1700nm 4hr. flight, we experienced the same problems Air France had while flying thru bad weather.
I have a link to the failures that occurred on AF 447. My list is almost the same.
http://www.eurocockpit.com/images/acars447.php
The problem I suspect is the pitot tubes ice over and you loose your airspeed indication along with the auto pilot, auto throttles and rudder limit protection. The rudder limit protection keeps you from over stressing the rudder at high speed.
Synopsis;
Tuesday 23, 2009 10am enroute HKG to NRT. Entering Nara Japan airspace.
FL390 mostly clear with occasional isolated areas of rain, clouds tops about FL410.
Outside air temperature was -50C TAT -21C (your not supposed to get liquid water at these temps). We did.
As we were following other aircraft along our route. We approached a large area of rain below us. Tilting the weather radar down we could see the heavy rain below, displayed in red. At our altitude the radar indicated green or light precipitation, most likely ice crystals we thought.
Entering the cloud tops we experienced just light to moderate turbulence. (The winds were around 30kts at altitude.) After about 15 sec. we encountered moderate rain. We thought it odd to have rain streaming up the windshield at this altitude and the sound of the plane getting pelted like an aluminum garage door. It got very warm and humid in the cockpit all of a sudden.
Five seconds later the Captains, First Officers, and standby airspeed indicators rolled back to 60kts. The auto pilot and auto throttles disengaged. The Master Warning and Master Caution flashed, and the sounds of chirps and clicks letting us know these things were happening.
J.S., the Capt. hand flew the plane on the shortest vector out of the rain. The airspeed indicators briefly came back but failed again. The failure lasted for THREE minutes. We flew the recommended 83%N1 power setting. When the airspeed indicators came back. we were within 5 knots of our desired speed. Everything returned to normal except for the computer logic controlling the plane. (We were in alternate law for the rest of the flight.)
We had good conditions for the failure; daylight, we were rested, relatively small area, and light turbulence. I think it could have been much worse. Jerry did a great job fly and staying cool. We did our procedures called dispatch and maintenance on the SAT COM and landed in Narita. That's it.
[/FONT]
You missed a name or two in there. I'd pull names and initials, the date and time, probably the city pair, too.
Except for elevator jack screws and rudder hard overs, that is
ONE improperly maintained jack screw fails out of all the basic9 and 80series ac.
It wouldn't have failed completely BTW even on that flight had they not kept screwing with the damn thing once it was jammed...and just did a precautionary landing with a slightly less than ideal trim setting...
So give me a break...
And who says the video game aircraft are immune to hard overs?
I'm not an engineer, but I'd guess that since the computers are monitoring the flight control positions and actuators, if an actuator had a hardover, it would be disabled if possible, and a fault would be displayed.
I always wondered why, when they had the aircraft in landing configuration, they felt the need to jack with it.
Thread creep off.
Gup
I call B.S. on this one guys - a detailed e-mail received from a "friend of a friend" less than 36 hours after the incident... I fly the little bus and find the scenario entirely plausible, however, this is reminiscent of the AF 447 cabin "crash photos".......
Can any NWA guys verify?
Baja.
If its true it will get around pretty quick. As for the guy talking about rudder hard over, both this incident and AF rudder protection is lost only. Any rudder excursion would most likely be induced by the pilot. BTW if the NWA story is true thank goodness the Capt most likely started his carrier on DC9 B727 or CV 580 and had some basic flying skill...
Have not heard any information on this from operations. It seems odd that after an event such a this, a pilot would be e-mailing this to a friend. I know that there have been other events with the A330, but this is a first. Operating the largest A330 fleet you would think that the "pitot tube" event may have happened earlier, certainly not right after the AF crash.
"they're immune because the rudder just leaves the airframe before it happens."
Alright that was some funny sh1t
http://www.avherald.com/h?article=41bb9740&opt=0
Incident: Northwest A333 over East China Sea on Jun 23rd 2009, unreliable airspeed
By Simon Hradecky, created Thursday, Jun 25th 2009 22:26Z, last updated Thursday, Jun 25th 2009 22:26ZA
Northwest Airlines Airbus A330-300, registration N805NW performing flight NW-8 from Hong Kong (China) to Tokyo Narita (Japan), was enroute overhead the East China Sea, when the crew noticed a sharp drop of the indicated outside temperature followed by the loss of the air data reference system, disconnection of autopilot and autothrust system along with the loss of speed and altitude information. The flight crew used the stand by systems and was able to restore the primary data. The airplane landed safely in Tokyo Narita.
The NTSB is investigating, the flight data recorders have been retrieved, the aircraft condition monitoring system messages, crew statements and weather information are being collected by NTSB investigators.
The NTSB reported, that a very similiar incident happened on May 19th to a TAM Airbus A330-200.
i don't have tons of experience with pitot tubes, but isn't the real issue here flying in thunderstorms? The weather description matches that of a severe thunderstorm, the same as the AF weather situation.
if it ain't boeing, i ain't going.
Like you really have a choice...It's only democratic when you have finally hung up your wings.
For ********************s and grins how about "without a table I'm not able"
My sentiments exactly. Notice how the letter writer only mentions "rain". He is avoiding the elephant in the room.
When the radar shows red below and green and yellow at your flight level, you are trying to top a TRW. Why not just 20 degrees right for weather (oceanic or not).
Similar
While a different class of aircraft, the Beechjet fleet suffered through this issue. I personally experienced a failure of 2 of the 3 airspeed indicators at FL390. We were just in the tops. We could barely see ice crystals. Smooth ride.
For our fleet they discovered that the front of the tube was heated and the base was heated, but the 90 degree bend was not. Thus the front would heat the ice just enough to melt it an then it froze in the bend. During our descent through about FL210, it melted and the two failed airspeeds came back to normal.
From the news reports today (and we all know how accurate they are) pitot tube problems are relatively common on all airplanes accoriding to the NTSB databse.
Baja,
You should really delete your post. Did your friend know that you were going to post it on a public message board? It isn't properly de-identified and there may be legal ramifications.
Baja,
I agree.
This is basically the NASAP report itself, on a public forum, with names in it.
That said, if I were in the crew I wouldn't have sent it out either.
