NTSB Final Report on Corporate Airlines 5966
  • Thread starter Thread starter Rogue5
  • Watchers Watchers 22
81Horse said:
The FAA doesn't think so either; it's not legal [on a nonprecision approach].
Why do you say that? What in 91.175's language leads you to believe it's not legal for a nonprecision approach? (Why would it mention both DA and MDA otherwise?)
The pilot, Kim Sasse, 48, and co-pilot, Jonathan Palmer, 29, ignored guidance about when and at what speed to descend the plane on its path to the runway, joking and cursing at one another while the plane's warning system alerted them of the rapidly approaching ground below, investigators said.
"I was extremely disappointed in what I heard" on the cockpit voice recorder, acting NTSB chairman Mark Rosenker said. "From the beginning to the end, it was unprofessional."
81Horse said:
The FAA doesn't think so either; it's not legal.
Ummmmm........are we talking about the same thing? It is legal with both precision and nonprecision approaches.
(c) Operation below DH or MDA. Except as provided in paragraph (l) of this section, where a DH or MDA is applicable, no pilot may operate an aircraft ... at any airport below the authorized MDA or continue an approach below the authorized DH unless--
(1) The aircraft is continuously in a position from which a descent to a landing on the intended runway can be made at a normal rate of descent using normal maneuvers, and for operations conducted under part 121 or part 135 unless that descent rate will allow touchdown to occur within the touchdown zone of the runway of intended landing;
(2) The flight visibility is not less than the visibility prescribed in the standard instrument approach being used; and
(3) ... at least one of the following visual references for the intended runway is distinctly visible and identifiable to the pilot:
(i) The approach light system, except that the pilot may not descend below 100 feet above the touchdown zone elevation using the approach lights as a reference unless the red terminating bars or the red side row bars are also distinctly visible and identifiable.
... and so on.
What in the above makes you think you can descend from the MDA before you intercept a normal glidepath to a normal landing on the intended runway? Because, if you do leave the MDA outside your circling radius (visibility and speed) or before you're in a position to complete a normal landing -- well, you would have no guarantee whatsoever of terrain clearance.
OK, so I have enough vis under a ragged cloud layer to see most of the approach lights 3 miles away. I will do a VERY shallow apporach to landing at the runway that I expect to soon see. Are you saying it is not legal to descend to 100 above touchdown in that case because I'm using a shallow approach angle instead of 3 degrees?
masedogg19 said:
Thanks....that's exactly what I was alluding to. I just didn't want to see any smart a** comments about them being stupid or making poor decisions.
That's what I'm saying. By the same logic, you're not supposed to duck under a VASI/PAPI or GS, if available.
Using your scenario, you have no assurance of obstacle and terrain clearance. You should continue (in your stated case, straight in) until you intercept a normal approach path (by published or calculated PDP, or VASI/PAPI/GS); if, at that point you have the runway environment in sight (by any of the allowable criteria), then you may descend as necessary to make a normal landing.
If you lose sight of the runway environment while circling (or after the straight-in missed approach point), you are supposed to commence a missed approach -- not duck under because you see the ALS.
Understand your point now. I agree with you that continuing on until you get a normal angle is the safe thing to do. I do not agree that this approach is not legal. Consider a day (no hidden obstacles) where you see the lights, but not the runway yet. Thanks.
OK....as I said before....I have the entire initial report...pictures and everything....I just read the transcript.....at NO time during the final approach phase were they joking or cursing at each other.....nor were they joking or cursing or ignoring the plane's warning system about approaching ground below.....the final report seems a little off.........
But the safety (i.e., terrain/obstacle avoidance) is built into the regulation and TERPS criteria -- there's no legal wiggle room for a judgment call on how much or when you can duck under the MDA early (before the normal approach profile).
Not understanding this reg could easily get you a down on a checkride. Well, and then there's the whole Controlled Flight Into Terrain thing.
Moderator reviewed. Enough already, Lequip...your point has been made. To post more along this line is deliberate flamebaiting and won't be tolerated.
