On Your Six
- Mar 8, 2004
Now hiring onto both the X and XL out of BWI. Why so much attrition with this flight department? It's crazy - I see this ad over and over again. You would think they would learn with so many people departing... Any thoughts? What's the deal?
Citation 750/560XL Pilots (MD) 6/26
Northrop Grumman Corporation is accepting resumes from experienced corporate pilots for Pilot-in-Command positions based in Baltimore, Maryland (BWI). Pilots hired into this position will serve on both the Citation 750 and 560XL aircraft. Minimum flight experience required is 4,000 hours total, 1,000 hours turbine, 500 hours jet, and 250 hours in the last 12 months. CE-750/CE-560XL Type Rating and 500 PIC hours in type is preferred, but not required. FAA ATP pilot certificate and Class I medical certificate with no waivers is required. Pilots will be required to perform other flight department duties assigned by management. U.S. citizenship is required. Must be eligible for DoD security clearance. A security background check and pilot record check will be performed. Multiple positions are available. Click here to apply online or go to www.careers.northropgrumman.com and select Flight Operations under the Quick Search of the Careers tab. Tell them you saw the ad on AvCrew.com.
