UM#1
- Dec 1, 2001
The FAA and the Airlines have agreed to utilize a new ATC initiative, known as the Flow Constraint Access Plan, in an effort to increase the National Airspace System (NAS) capacity during times of high volume constraints. This program
is designed to give ATC flexibility in order to avoid ATC sector saturation and reduce miles-in-trail restrictions. Beginning March 22, 2004, on days when this plan has been executed, crewmembers will be informed by remarks on their release that they should fly the route and/or altitudes as filed. Do not ask for reroutes outside of the initiative as this could place new constraints on the airspace. Data from this initiative will be collected and evaluated to help improve the National Airspace System (NAS). Your help is appreciated.
In addition, the Industry has agreed to let the Air Traffic Control System Command Center delay and reroute flights from surrounding airports when taxi out delays exceed 90 minutes at any given airport. This may affect our flights in the Chicago and New York areas, so be prepared for departure delays when a near by airport is reporting lengthy taxi delays.
