NJA's Newest FO Bid and Which Domicile
560NJA
Member
Total FO slots - 56
CE750 - 12 slots
1 - CMH
5 - LAX
3 - PBI
3 - TEB
G200 - 8 slots
2 - CMH
2 - DAL
3 - PBI
1 - TEB
BE400A - 14 slots
5 - CMH
3 - LAX
3 - PBI
3 - TEB
CE560 - 12 slots
2 - CMH
3 - DAL
2 - LAX
3 - PBI
2 - TEB
CE560E - 2 slots
2 - CMH
CE680 - 8 slots
3 - CMH
1 - DAL
4 - LAX
Just so all you that are waiting know what is being offered. Good Luck!
Folks, don't get the wrong idea here. These vacancies come out once every quarter or so and usually do not have this many options. Those of you who are thinking, "I can get into LAX or CMH now and get PBI or DAL on the next bid," ....think again. Reality check: if you hire on now, in my estimation, you will report to the domicile into which you hired for AT LEAST 3 YEARS.
If you can stomach the move to your assigned domicile, maybe it is a good option. Otherwise, I would recommend NOT commuting more than an hour or two and waiting until this gets resolved with the next contract. The company is playing games with this one and you might be better off not becoming a pawn.
There, I feel better.:erm:
with the two year seat lock for FOs transferring airplanes, do you see much in the way of FOs bidding on these vacancy bids?
FO's very rarely bid on this bids, this is part of the CBA, they have to first offer the slots to the pilots here before they hire people into these slots.
I am sure less than 20 and probably less than 10 FOs have switched domiciles with these bids in the past. I'm guessing since this is a big bid, there may be a few guys or gals switching around, but most of these slots will be open for newhires whenever they start. It won't affect the number of pilots hired, just the places they are put. Good luck all getting the base you are looking for- at least there are some slots outside of CMH and LAX available in the near future.
There is a 2 yr domicile lock (waived once) and a restriction from bidding another Class 1,2,3 a/c as an FO ever again. This means if you hired on, switched domiciles, you would be in your seat until you upgraded (no aircraft changes), got a class 4/5, or went to nji. For a newhire now, that could mean a long time.
When can FOs start bidding these? When does the equipment lock begin- on day one of company training or on day one of aircraft training? Would it be possible to start company training and then bid to another aircraft before beginning aircraft training- which in my case will be exactly 1 month from the day that I start company training. I'm slated for the BE400 right now and would like to switch to a busier fleet if possible.
Have you asked if you could wait for a later class at the same domicile? If you really want to avoid the Beechjet that might be the way to do it - it doesn't hurt to ask - right? That being said, seniority is everything from what I have heard. If you compare the Beechjet to the X in terms of schedule, it is like comparing night and day - the X crews are evidently worked like slaves... Multiple transcon flights per tour - that would be exhausting in that tight cockpit.
I'd say enjoy your "rest" on the Beechjet before you get a busier fleet down the line... Let us know how it pans out for you.
