NJA LOA on changing Domiciles reached for newhires!!
It's an improvement, yes; but I think the label "win" is an overstatement. There are definitely some strings attached. After an FO bids into a new domicile (from the one originally assigned) he/she is no longer allowed to bid for any other FO positions on another aircraft in classes 1-3. That should cut down movement between the fleets, and therefore training costs, one can surmise. The 2 year domicile lock will restrict movement, making it easier to project hiring needs for the domiciles. Potential new hires have asked about the possibility of changing domiciles. Perhaps, there have been enough questions to get the message across that the salary doesn't offset the negatives of being stuck in an expensive city you don't like. If that's the case, the flexibility will be used as an inducement to interviewees.
Those are 3 that I see, the NJ pilots may know of others. Hope that helps.
NJW
notaNJApilot said:
So now a pilot might choose to pass up on a captain upgrade if it is not in his preferred domicile. This would be a loss of money since he is going to remain as a FO until a captain slot in his domicile opens up. I guess this LOA is good and bad.
At first I thought this was the case as well, but it is not. This LOA does nothing more than allow for domicile transfers on a seniority basis. You do not have to change domiciles if you don't want to, and you don't need to change domiciles to upgrade either. However, if you want to upgrade and change your domicile at the same time you can do that now thanks to the LOA. There is no such thing as having a PIC CE750 TEB slot for an upgrade and a domiciled pilot having to move from DAL to TEB in order to upgrade.
I just find it ironic that 10-12 months ago during the height of the negotiating furor, many of the 1108 posters on this board were telling interested applicants not to come to NJA until after the new CBA. "Don't come here now" they said. "It'll be better after the new contract" they said.
Of course, the smart ones ignored that advice and joined the company before the new contract and received HBA rights as a result. Kind of damages the credibility of some of the advice on this board, doesn't it?
No. It was advice based on information at the time.
The Domicile issue reared it's head in the final offer given by the company with the ultimatum... "take it or leave it".
The ones who came here took a gamble and got HBAs. Just the way it worked out.
Absent a good contract and after seeing the POSTA the best advice WAS to avoid this place like the plague.
It was sound advice.
It's a NJA thing...you wouldn't understand... unless you lived through the roller coaster ride of negotiations lasting 4 years and ending with a derailment called the POSTA.
I wouldn't say the ones coming here against advice were smart necessarily... they were indeed lucky though.
I'm another that doesn't think credibility was damaged. Yes, I was vocal about my family's situation; I wanted other pilots to be aware that they had been misleading candidates during the interview. I advised all interested applicants to take a good look before they leaped in. For the ones who PMed me, explaining why they were still interested--young and single, mostly--I answered their questions and wished them luck.
The domicile debacle did come as a surprise to many. I know there was talk of it being just a "scare tactic", or a deterrent to HBAs. Some of us thought it was included in the POSTA, just as a show of pride (as in a "we're not backing down boast") or intimidation. Those theories are still there, if you'll notice. Now its called a diversionary tactic, or a future bargaining chip to keep salaries from rising. I think the problem is that the idea sounds so unfeasible for the frac industry that it's hard to take it seriously, at face value. People keep thinking that there must be more to it....only 5 cities....:confused: As I said when my husband first told me about it....You're kidding , right?
Let's face it, the advice was a negotiating tactic. The thinking was, fewer applicants=fewer pilots=lower dispatch rate=more pressure on the company to settle. No complaints, you do what you think necessary to win your battle. But let's call a spade a spade.
NJA is like any other airline: seniority is everything. Most applicants, including a friend of mine, knew that getting on the property sooner rather than later was a good idea. He knew the contract would get done, he rolled the dice, and he made the 7 on the come out roll.
Being that this is an interview and employment intel web site, the point is that any advice given about any company should be viewed with several grains, er, make that pounds of salt. There are many agendas at work and job seekers would be well served to remember that.
Yes, that spade was there for some, but you tied it to the domicile issue as though we knew how it would end up. That's not fair to say. I also think that the pilots who had that strategy did believe that it was the course of action that would help the most pilots in the end. They didn't believe the job was worth having unless the compensation improved significantly. Judging by the strike vote they were right.
My husband also points out the importance of seniority. You will see that advice reflected in my posts to those who have been holding out for DAL.
I agree that readers should sift the posts carefully to glean what they can. It's good to keep in mind, too, that the other half of the board--PMs--are an excellent source of information.
So if ones desire is to upgrade as soon as possible. Which domicile will do that for you. Could you be stuck at a "senior" domicle and stuck in the fo slot with people hired after you at different domicile upgrading????
That wouldn't happen because pilots are allowed to switch domiciles for the purpose of upgrading. In that situation the 2 yr domicile lock won't be applied. The pilots will be required to fill out a Standing Bid Form (and ya better keep it current because the awards will be based on that) that states their priority--domicile location or upgrade time. If you elect to upgrade asap then you will be offered (assuming you're eligible to bid for it)the domicile/plane slot that meets your goal. As long as you were willing to change domiciles to the one with the upgrade opportunity, it would go to you before it was awarded to a pilot who had been hired after you.
I'm sorry that I can't predict which domicile would give you the quickest upgrade. If there's a method to their madness, I haven't seen it yet. :rolleyes:
BINGO!
Not to detract from anyone who was giving advice then, but it was BAD
advice for those who had the chance to come early but waited until after the T.A. was ratified.
NJWife, I have to respectfully disagree with your interpretation of the LOA. No post CBA pilot will have to switch domiciles in order to upgrade. Like our union president describes, you have to think of the LOA as two parts, 1)the preference to change domiciles and 2)the opportunity to upgrade. There essentially will be no "senior" domicile regarding upgrades the way I understand it. The question was posted on page 1 of the three page thread located on our union message board, I paraphrase: "for a post CBA pilot to bid for the first available upgrade he or she might be forced to transfer to a different domicile or forgo the first available upgrade opportunity?" If you look further down the same thread, you will see how our union president explains that this will not be the case.
I hope I am not misunderstanding what you are trying to say, and I certainly hope I am not misunderstanding the LOA. If I am incorrect I want to make sure I have the correct information. :D
No. No games.
The mamagement of this company killing NJA swiftly enough without the pilots getting involved to make this job undesireable.
When the pilots of NJA lost enthusiasm as a normal reaction to the POSTA, the advice of "don't come to NJA" was very sound and solid.
I, personally, didn't see NJA lasting indefinetely without a dedicated frontline force of pilots.
Why ask guys to come here for an environment like that.
The scales were so tipped in the pilots favor, we didn't need to imbelish how crappy it would be coming to work at NJA. It was crappy.
Now in terminals around the US... I am happy to report that after years of silence, AA and Delta pilots have broken the code of silence with us to ask us about NetJets. :eek: :eek: :eek:
Lear70 said:
BINGO!
Sorry, but if you base your career decisions on advice you receive on flightinfo, then you deserve whatever result you manage to achieve.
Lear70 said:
BINGO!
No because there would not have been a contract worth coming for ... ie $27K/yr pay.
Gutshotdraw posted:
I would agree with that statement if all the new hires were clairvoyant, but at the time there was no light at the end of the tunnel. There were not even any rumors that the TA was around the corner, so your premise is not valid.
I imagine most people were looking for work and did what a lot of us did when in that situation. They took the job to feed the family, conditions be danged.
PS
I had a old Army bubba call me last year inquiring about NJA. I told him as a NJA pilot I would advise not coming here for (fill in the blank) reasons. I then told him as a former army brother I'll do anything I can to help you get on if you so chose. ;) He was hired a month or two before the TA hit the streets. Moral of the story? You do what you have to do.
So what is the answer?
I've read through the LOA for the first of many times, and I don't quite understand it. Is the trick to use the "domicle lock wavier"? It seems as if with this LOA, a junior pilot will get a Captain award over a more senior pilot as long as the junior pilot is willing to move to the domicle associated with that Captain award.
I am still waiting for "official" clarification on the subject, but our union President makes it quite clear on the union board that this is not the case, that a pilot will have to switch domiciles in order to take the first available upgrade opportunity. The captain vacancy bids that are posted now do not specify an aircraft and domicile, and as I understand it, neither will they in the future. I believe that the LOA will allow domiciled pilots to 1) change domiciles as their seniority will allow, or 2) upgrade to captain and switch domiciles if their seniority will allow it. It definitely is not worded the best, so I am just going off of the limited information B.O. has posted and waiting to hear back from my P2P rep.
The examples in the LOA led me to believe that postings will be made with Aircraft, rank, and domicile. I can't imagine this LOA forcing a pilot to move in order to receive an upgrade, but it seems like the pilot might have to wait longer for that upgrade to happen in his current domicile, unless he uses the domicile lock wavier...what else would the wavier be used for?
I don't know for sure, you bring up a good point with the domicile lock waiver. Like I said, I don't understand this LOA completely and I am waiting for answers also. I interpreted Olson's post on the union board in a way that you would not have to change domiciles in order to take the first available upgrade.
1) A pilot may stay in their initially assigned new hire domicile and upgrade at the first opportunity. The pilot will be awarded the most preferred aircraft their seniority will hold based on their preferred standing bid - fist, second, third, etc.
2) A pilot may transition to a new domicile when an opening at a more preferred domicile is offered in the pilots current fleet and seat.
3) A pilot may "swap" domiciles with any pilot in the same fleet and seat at anytime.
No pilots will incur a restriction on upgrade opportunities based on a domicile assignment whether it be their initial new hire domicile or a domicile a pilot transitions into. The aircraft bids remain system wide bids and will be awarded solely on seniority, regardless of domicile.
I hope this is helpful,
I agree with this, this is how I interpreted the LOA from the beginning.
