STOP LOSS Message
ATKTK,
The 60-Day review is in this message from the AF/DP in paragraph 2. I submitted another retirement application two weeks ago and it's in the wickets. I'm sure it'll be approved pending the end of STOP LOSS. Best wishes to all.
FIRST...FLY THE AIRCRAFT !
SentryIP
volamus@icqmail.com
Sent: Monday, January 28, 2002 6:35 PM
To: CC
; CV
; DO
; DP
; HC
; HO
; IG
; IL
; JA
PA
; RE
; SC
; SE
; SG
; XO
; XP
; CC
dda:ACP-PLAD=ALMAJCOM////CV//DP////; HQDCANG
; ALPERSCOM; FM
PA
; AQ
; LL
Cc: DPF
Subject: Stop Loss Review Update #2
Importance: Low
UNCLAS
1. FOLLOWING AN IN-DEPTH REVIEW BY MAJCOMS, AIR RESERVE COMPONENTS, AND FUNCTIONALS, THE ASSISTANT SECRETARY OF THE AIR FORCE FOR MANPOWER AND RESERVE AFFAIRS, PPROVED THE RELEASE FROM STOP LOSS OF 24 OFFICER AND 40 ENLISTED AFSCS. A NUMBER OF FACTORS WENT INTO THIS DECISION, TO INCLUDE ONGOING AND FUTURE AEF REQUIREMENTS, OPERATIONS NOBLE EAGLE AND ENDURING FREEDOM HOMELAND DEFENSE NEEDS FOR THE NEW STEADY STATE ENVIRONMENT, AND AIR RESERVE COMPONENT MOBILIZATION.
2. THOUGH WE REMAIN FOCUSED ON ENSURING OUR FORCE CAN MEET ITS ONE/OEF REQUIREMENTS, WE ALSO RECOGNIZE THAT WE MUST BEGIN TO RETURN THE TOTAL FORCE TO A MORE NORMAL STATE. THE GRADUAL RELEASE OF AFSCS PUTS US ON THAT GLIDE SLOPE. SINCE THIS IS A VERY DYNAMIC ENVIRONMENT, WE WILL CONTINUE TO REVIEW THE STOP LOSS PROGRAM EVERY 60 DAYS AND MAKE ADJUSTMENTS ACCORDINGLY. IF WORLD EVENTS CHANGE SIGNIFICANTLY, WE WILL RE-EVALUATE STOP LOSS DECISIONS IMMEDIATELY.
3. ACTIVE AND RESERVE COMPONENT MEMBERS, NOT MOBILIZED OR DEPLOYED, IN THE FOLLOWING DESIGNATED AFSCS AND WHO HAVE AN APPROVED ETS/DOS/DOR MAY BE ALLOWED TO SEPARATE/RETIRE NET 1 MAR 02. SERVICING MPFS WILL CONTACT AFFECTED MEMBERS TO REVIEW THEIR OPTIONS AND SELECT A DEPARTURE DATE. THOSE PERSONNEL WHO HAVE AN AFSC ON THE RELEASE LIST, BUT ARE DEPLOYED OR MOBILIZED, TO INCLUDE RESERVE COMPONENT MEMBERS ACTIVATED IN-PLACE, WILL BE ALLOWED TO SELECT A SEPARATION DATE NET 30 DAYS AFTER RETURN FROM DEPLOYMENT, DEMOBILIZATION OR DEACTIVATION. MEMBERS RELEASED FROM STOP LOSS WILL BE AFFORDED SUFFICIENT TRANSITION TIME, INCLUDING TIME TO COMPLETE NECESSARY TRAVEL, COMPLETE MEDICAL EVALUATION IF REQUIRED, AND USE ACCRUED LEAVE IF DESIRED BY THE MEMBER. COMMANDERS OF MOBILIZED/ACTIVATED RESERVE
COMPONENT MEMBERS WITH THE SPECIFIED AFSCS, WHO ARE OTHERWISE ELIGIBLE FOR SEPARATION OR RETIREMENT AND WHO HAVE BEEN DEPLOYED, SHOULD GIVE CONSIDERATION TO REQUESTING THEIR DEACTIVATION UPON RETURN FROM DEPLOYMENT.
3A. OFFICER: THE FOLLOWING OFFICER AFSCS WILL BE RELEASED FROM STOP LOSS AS DESCRIBED ABOVE - 13S, 21A, 21M, 21S, 35B, 36P, 38M, 42B, 42E, 43A, 43D, 43M, 44D, 44H, 44J, 44Z, 46G, 47B, 47D, 48E, 65A, 65F, 65W AND 84H.
3B. ENLISTED: THE FOLLOWING ENLISTED AFSCS WILL BE RELEASED FROM STOP LOSS AS DESCRIBED ABOVE - 1C6XX, 1S0XX, 1T0X1, 2A000, 2A0X1, 2A1X1, 2A1X2, 2A1X3, 2A300, 2A3X1, 2A3X2, 2A3X3, 2A4X1, 2A4X2, 2A5X3, 2A6X3, 2A7X4, 2M0XX, 2P0XX, 2R0XX, 2R1XX, 2T3X5, 2T3X7, 2W0XX, 2W1XX, 2W2XX, 3A0XX, 3C0X2, 3C3X1, 3H0XX, 3N0XX, 3N1XX, 3N2XX, 3U0XX, 4J0XX, 6FXXX, 8FXXX, 8M0XX, 9DXXX AND 9E000.
4. IN ADDITION, ACTIVE DUTY LINE OFFICERS WHO ARE TWICE-DEFERRED FOR PROMOTION AND HAVE NOT BEEN OFFERED CONTINUATION, WHO ARE NOT DEPLOYED, ARE RELEASED FROM STOP LOSS. OFFICERS WHO MEET THESE CRITERIA BUT ARE CURRENTLY DEPLOYED ARE RELEASED FROM STOP-LOSS UPON RETURN TO HOME STATION FROM DEPLOYMENT. OFFICERS SUBJECT TO THIS PARAGRAPH WILL BE SEPARATED ON THEIR
MANDATORY DOS/DOR, EXCEPT THAT OFFICERS WHOSE DOD/DOR FALLS BEFORE 31 JUL 2002, OR WITHIN 150 DAYS OF RETURN TO HOME STATION FROM DEPLOYMENT, WILL BE PERMITTED TO ESTABLISH A NEW DOS/DOR SO AS TO AFFORD THE OFFICER 150 DAYS TRANSITION TIME.
5. IT IS IMPORTANT TO NOTE THAT PERSONNEL REMAINING UNDER STOP LOSS MAY CONTINUE TO APPLY FOR SEPARATION/RETIREMENT THROUGH THE WAIVER PROCESS. IN
ADDITION, STRONG CONSIDERATION SHOULD BE GIVEN TO WAIVER REQUESTS FROM HYT PERSONNEL.
6. IMPLEMENTATION INSTRUCTIONS AND DETAILED GUIDANCE FROM AFPC, AFR AND NGB WILL FOLLOW. MY THANKS TO ALL FOR MAKING THIS PROCESS WORK. POCS ARE LT COL JAN MIDDLETON (AF/DPFMP), DSN 225-4679, LT COL RICH BINGER (AFPC/DPPRS), DSN 665- 2792 AND MSGT MIKE POTTER (AFPC/DPPRS), DSN 665-2374.
