USMCFDX said:Humbly disagree with you FedExFlyer, I think you would be a fool not to take the DC-10 S/O slot. Easy job ( not much to do after 18K in the climb), pay almost the same as a 727 F/O, better trips being junior (even with the -10 going away), good place to learn how FedEx works, and if you do happen to be excessed out in a year or two ther will be someone junior to you in the 727 F/O seat so you could go there then, and probably could go to the the madDog the way things are going. My .02
USMCFDX said:Humbly disagree with you FedExFlyer, I think you would be a fool not to take the DC-10 S/O slot. Easy job ( not much to do after 18K in the climb), pay almost the same as a 727 F/O, better trips being junior (even with the -10 going away), good place to learn how FedEx works, and if you do happen to be excessed out in a year or two ther will be someone junior to you in the 727 F/O seat so you could go there then, and probably could go to the the MadDog the way things are going. My .02
psysicx said:Why did the 727FE seat suck?Is LAX really senior still ?
General Lee said:LAX is not really that senior, except for the 765 (or 764 INTL---Hawaii flights).
I didn't like the FE seat because you were treated poorly by the FO, who usually was the laziest pilot on the planet.
Bye Bye--General Lee
psysicx said:How long does it take to upgrade from the 727 panel to the right seat of the 727 then to the right seat of the MD?
