NetJets - distance from base?
Rough67
5 t's
I tried searching and can't find the info anywhere. I was wondering if you are based in LAX (for example) how far away can you actually live (thinking about San Diego)? Is there a certain callout time or is there just a point in time that you have to report there by. I saw an earlier tread that said somthing about knowing the day prior if you'll be used or not, and it sounds like you could live several hours away from a base. (if you're willing to drive it.)
thanks.
You can live anywhere you want...You just have to be at your domicile at your showtime. You will have at least 10hrs notice of that showtime.
Remember though, you may have to work up to a 14hr day...may not want to spend you rest period traveling to LAX.
Tough situation. We have had a lot of folks commute to work and it sucks. But, at least you will have a report time and can plan accordingly.
You can live anywhere you want but must be within 90 miles of your assigned domicle when on duty. The night before thing is for reserve duty which you probably won't have to be on except right after training. Reserve pays quite a bit more than the 7-7 schedule so I doubt anyone will be junior assigned it.
With the 7 on 7 off you could live quite some distance away since you're not having to come to work that often. Before the current pilots were given home basing we had guys driving 7 hours or more to their gateway.
Edit: 54 pilots were junior assigned reserve, mostly F/O's on the Ultra and Excel. That's only 2.4% of the pilot group.
Hey Bear,
You sure about the 90 mile thing? I thought it went away...
Nightmare67 said:
Hey Bear,
You might be right. The only reference I can find applies to Pre-TA pilots who live within 90 miles of one of the 5 domicles. They have to use that domicle instead of a HBA. Since we don't sit "Short Call" reserve at NJA it really doesn't matter that much. Just be there for your show time.
AirBear
AirBear
Ya, I went back and looked too...I agree with you that it only seems to address pilots here at or prior to ratification...So I assumed (ya I know) that if you came here after ratification, you have to show at domicile. No requirement on where you live.
Oh well...
Current paperwork sent with application as of a few days ago states you "must be within 90 miles by midnight on their first day of duty." This referring to your domicile. This is item 7, page 4. Good luck with your decision!!
Distance to base requirement?
I want to make sure I understand this correctly. I currently live 2 hours from TEB. When I'm doing reserve or if I'm in the middle of a 7n7 tour I need to be within 90 min? Or do you need to permanently relocate to within 90 minutes of your base? Thanks for clarifying this for me!
I live in ATL and can't move anywhere right now. I just got the app in the mail. What are the chances of getting HBA in the next year or two if hired? Also, if after a tour you can request an alternate DHD and pay the difference, correct?
Cheers
Cheers
I would guess your chance of getting an HBA is less than 1%. I would say 0% but I wanted to leave a little room for a mirracle. Yes after a tour you can tell NetJets you want to go to a different airport. You make your own reservation and the company will reimburse you what they would have paid but no greater than the actual cost of your ticket. We bid our schedules quarterly.
You can live wherever you want. Period. If you want to live in Nome Alaska but your domicile is Palm Beach, then live in Nome. There is NOTHING in the current CBA that tells you where you have to live. The only thing required of you is to be at work on time.
Going2Baja, The information that was sent to you was based on the the old CBA.
I figured, but had to ask anyway.
I am still thinking of making the jump so tell me more about the 7 on 7 off deal. When do you have to be in position at your domicile? How far in advance do you know where you are going during the 7/7?
Thanks in advance!
At you briefed show time. You will be briefed the evening before your first day of duty what time you need to show.
at NetJets you NEVER know where you are going until you are actually going there. Even then you still don't really know for sure.
Then NJ Corporate has it printed incorrectly. On the same page it has the new contract pay and basing requirements.
Hi!
I was under the impression I couldn't work for NetJets, because I live in Green Bay and can't move. Do they have a base in ORD (or MDW)? If they do, it sounds like living in GRB would work for NetJets if I was based in Chicago???
Cliff
YIP
Curious if there have been any new hires since the TA was ratified that were able to get assigned homebasing?
VVJM265,
All new hires will be assgined a domicle. Currently 5 locations. The company is allowing the person to pick from the 5 domiciles. The domiciles are TEB,PBI,DAL,CMH,LAX.
Home Basing is only avaliable to all pilots here at the time of ratification. All new hires will have to wait until they are in top 30% of senority list to hold HB.
I have read that people think Home Baseing will change. Possible, but that is not how it is written. I don't see the companies motivation to change it now. I am only pointing out what are the current facts. Hope this helps in making a choice.
infoman.
infoman said:
VVJM265,
infoman.
Infoman,
Thanks for the input. I read back thru this entire thread and also thru the contract posted on the union site. I have to wade thru it a few more times, but if I understood, you can live away from your domicle, you just need to be w/i 90 miles by midnight prior to your rotation. If that is correct then it but a new twist on things from my persepective.
Thanks again,
265
VVJM265 said:
Infoman,
Thanks again,
265
Not quite...Live where you want, period. You must be in position at your briefed show time. Thats all. Simple.
The 90 mile thing is for pilots already here at ratification. If you lived within 90 miles, you were a domicile based pilot with the option of moving farther out and being an HBA pilot.
All newhires have to REPORT to their domicile. Live where you wish.
Think of it like an airline job only you dont have the jump seat to get you to work.
265,
You are correct that you can commute to your domicile. Also your 90 mile enterp is correct.
Best of Luck.
infoman.
Thanks for the info gents.
Sidebar:
gunfyter said:
which Squadron is JM?
Wrt my "screen-name," VV = Navy, JM = USN air logistics assets w/i EUCOM which are tasked by the notorious ASCOMED, 265 = the Saberliner which I cut my teeth on in what seems like a gillion years ago (Mt Etna there from a squadron photoX).
I had the good fortune to do 2 tours in Italy, one flying the N265 & the other flying the SA227.
Thanks again for the info, I'm sure I'll have more questions in the next few weeks.
VVJM265
infoman said:
VVJM265,
infoman.
How hard is it to get based in Dallas?
Supposedly they are still allowing newhires to choose which domicle they want to use. With that in mind you should be able to get it right away.
Bad info there Infoman. The 90 miles by midnight was from the old CBA. There is NOTHING in the new CBA that even implies that this is still the case.
One more time...live wherever you want, show up to work on time.
