NetJets 2000EX
ultrarunner
This is interesting...especially when you do the math...
".....On Sunday July 24th 2005 the Falcon 2000EX flew its 1st passenger leg....The Bangor-Venice trip was 7 hours and 19 minutes and the aircraft landed with over 3,500lbs of fuel on board (nearly 2 hours of fuel remaining).
...Yesterday the Falcon 2000EX flew from Le Bourget Cedex-Paris to Columbus, OH, non-stop with a flight time of 9 hours and 16 minutes....
Hmmmm....how slow did they have to go to keep that beast in the air for 9.3 hours...
...prly not an accident they didn't post the block-in fuel in that second statement...
It had to be thin!
Would some 2000EX experts chime in. I'm reluctant to tell my boss stuff like that, since he'll expect it. We are considering this airplane. Could you have done Legourget - CMH faster going at a higher mach and making a stop?
The vast majority of our "A Team" or "Go-To Team" or "I'll Do Anything" guys are in the Falcon. Who needs rules when your an "A Teamer?"
It had to be thin!
M77, landing with 1600lbs, perfectly legal
Did they have to repo to LA after that? They did have about 5 hours of duty time left! (Something Options would do)
Definately dont go on what those NJA EX guys did. Those guys are the top of the seniority list and every bit the "A" teamers at NetJets. If the company asks, they'll do it. If its ????? they'll still do it. They have been at NJA for all these years for a reason...something in their background wouldnt let them get another job.
Well, maybe...
I tried running the flight plan at M77, M74 and LRC this afternoon and could not arrive with any fuel (figured zero reserve). Book values show the trip at M77 (no wind) arriving with 1836#. Fuel to 100NM alternate was 1483. Not leaving much room for error. I didn't even look if there was a wet footprint.
A crew did Maui-Nassau not long ago in a litte over 9 hours and had ~1200 remaining. That was with a significant tailwind and flying at M74.
While they may have been "legal" they may also have been "foolish."
I'm not defending the crew that flew the trip....nor do I have ANY experience with the 2000.....but do they really need an alternate if the weather is good for landing at CMH, with multiple airports within 20NM that they could put a 2000 down at? I would hope that, if they were landing that light, they checked the weather along the way over the Northeast, and planned a landing short of CMH if weather and/or airport conditions dictated.
Why keep the thing in the air that long?
How about highspeed cruise to bgr then highspeed to cmh.
What is the big deal about going non stop. Especially when an ultra is passing you.
To say that they did it? It's a psychological thing, going non-stop to the pax is faster than making a stop...even if it isn't true.
I didn't even know an Ultra could go M77. ahahha
If they would have bumped it up to 82 they probably would have saved 15 minutes in the air. The increased fuel burn would have required a stop, probably an hour in Gander or BGR. So they would have burned more fuel, increased the total travel time and put additional cycles on the aircraft. You guys should be happy. It's efficient and not wasting company money, unless of course you count a 9.3 hour ferry as a waste of money. The flights were "test" flights though. I can't think of the proper terminology right now. Proving flights maybe??
If was the crews choice to go non-stop, I haven't met a pilot with-out an ego that needs stroking. hahaha
Sad, but true. Often it's something the company that put in their file and often it's a bunch of BS. I know... A bizzare way to get loyalty. Like the scabs we have here who would probably support ASAP if they weren't already blacklisted. They have no where else to go!
Under Part 91, you are correct. Only need VFR and 30 minutes fuel to land. I don't know what NJA's ops say however. I used the 100NM divert as that was a readily available number in the manual.
Flight operated under IFR. Right?
Proving runs...They are proving the aircraft can do what the manufacturer says it can do.
